Old 04-10-2012, 11:06 PM   #1
2fast4u
2fast4u is on a distinguished road
Exclamation mk3 supra power steering fluid
hello ive got a 1990 toyota supra turbo with the 7mgte. i went to oreily auto parts to buy power steering fluid for my car. they told me i have to use dexron type automatic transmission fluid so they told me use dexron type 4. i put dexron 4 no problems or sounds but the manual says use dexron type 2. iam concerned that i might be ruining my power steering
2 fast 4 u
2fast4u is offline   Reply With Quote
Old 04-10-2012, 11:37 PM   #2
It's Dexron VI (6) not IV (4, never existed as a final product. No such thing as V or 5 either.). It is backward compatible but I recommend you fully replace the old fluid. The viscosity between the two is different and while it's still not well mixed in a power steering system you may notice off and on excessive response or resistance. Also, as it's thinner and will have active detergents, if you have a leak, expect it to be worse.
Old 04-10-2012, 11:45 PM   #3
2fast4u
Default mk3 supra
what do you recommend putting in becuase when i did the head gasket i removed the power steering can/filler. there fore when i was done with the head gasket i just filled it up with dexron 6. VI. should i drain and redo it and if so with what kind of fluid.
2 fast 4 u
Old 04-11-2012, 12:32 AM   #4
Oh, they're technically safe to mix so if you've had it in there for a while I wouldn't sweat it. Nonetheless, changing the fluid completely isn't a bad idea.... It's probably never been done before. I would use Dex VI for the lower viscosity, higher shear resistance and lower friction coefficient. I'd change it out a second time after a month or two because all the fresh detergent it likely to loosen up a fair amount of crap.
Old 04-11-2012, 04:07 AM   #5
2fast4u
Default Mk3 supra
If i change it which pipe would be the return line
2 fast 4 u
Old 04-11-2012, 05:58 AM   #6
The return is low pressure... Has constant tension clamps as opposed to crimped fittings.
No power steering 90supra MKIII Supra 1 11-01-2010 01:17 PM
Power Steering cables wet (leak) question rjSupra MKIII Supra 2 09-20-2010 11:34 PM
94 Supra TT with idling and lost of power issue bayatt MKIV Supra 4 03-12-2010 01:29 PM
power steering wont bleed please help. carnahkt MKIII Supra 5 01-24-2009 09:20 PM
power steering kylesupraturbo Non-Generation Specific Questions 5 01-08-2009 05:19 AM
