Old 04-06-2012, 12:45 AM   #1
lucioortiz
lucioortiz is on a distinguished road
Exclamation Help With RPMS
so i bought a toyota supra 87 turbo, a few months its working fine then outta the nowhere, 1st gear i could rev till i red line it, 2nd and above, it doesn't pass 3 thousand rpm, it starts stalling. we took it to the mechanics and they couldn't find out. it seems like the wires have been tampered with cause it has lots of mickey mouses and tape all around .... if anyone has an idea with that it is ill appreciate it.
lucioortiz is offline   Reply With Quote
Old 04-06-2012, 01:49 AM   #2
essial
essial is on a distinguished road
Any codes? (Even with no CEL there may be codes. I'd reset the codes -- unplug the battery for a minute or two, drive it around for a bit, then see if any codes come up). Could be any number of sensors, wires, or the like so codes would definitely help.
In general it could be a sensor screwing up the air/fuel mixture, or even something like a dizzy a tooth in the wrong direction. Definitely sounds like an emissions system issue though. Your Turbo could also have a crack somewhere, causing air to come in (past the maf, which is never a good thing). This would make issues happen when the turbo spools of course.
essial is offline   Reply With Quote
Old 04-06-2012, 04:43 AM   #3
Check for codes FIRST... Then clear any codes, run the car until it reaches normal operating temp and the fault occurs again and check again for persistent codes. Details on how to check them and what they mean is in a thread in the MKIII FAQ section.
Do not continue to bounce the engine off the rev limiter! You're setting yourself up for nothing but significant damage with this bizarre diagnostic technique.
Old 04-06-2012, 12:05 PM   #4
essial
Yeah hitting redline in 1st I'm assuming he just means it goes all the way up no problem, I think from 2nd on the system chugs at 3k rpm and doesn't go higher.
Old 04-06-2012, 06:28 PM   #5
Trust me... never assume the best when it comes to DIY mechanics... Often they'll blow your mind with what they believe is a good/safe/reliable idea. Like wetting your hands in gasoline and rubbing down intake hoses and vacuum line with them.... seen it.
AFM or an intake leak is possible, so is faulty knock sensor(s) or know sensor wiring or CPS problems. A lot of possibilities though.
Tags
revs, rpm, supra, toyota, turbo
Car dies coming down from high rpm's alexscof MKIII Supra 6 11-23-2009 11:16 PM
Please help...93 N/A high RPMs uberbg MKIV Supra 5 11-12-2007 04:04 AM
1986.5 Idling at high RPMS Sasukevh MKIII Supra 2 06-14-2007 04:56 AM
Engine seems powerless until higher RPMs Ahmad88 Non-Generation Specific Questions 8 06-22-2006 01:58 PM
Sputter @ high rpms with pedal all down! MKIIISupraTurbo Non-Generation Specific Questions 2 11-11-2005 01:47 AM
