Old 10-06-2005, 08:48 PM   #11
SupraMan1784
ummm..haha a turbo?
Now: Saving for an MKIV
Broken Rides:
Old 10-06-2005, 08:53 PM   #12
SupraMan1784
haha ok that was the obvious answer...since it usually solves most problems.. or you can supercharge it...but thats if you want to go the boost route...if you dont...then u have a a good start since u have the basics down, next step you need to address is fuel...more fuel...more air...get a fuel rail and a bigger intake manifold, or try velocity stacks...aka individual throttle bodies, get some cams and cam gears, get the head redone...ported and polished...same with the block...get suspension for handling...good set of coilovers or a nice combination of springs and shocks...strut bars and anti sway bars...upgrade the clutch, if you want get it tuned..with a piggyback or a standalone...depending on how much power you will want...its definitely a plus since you'll be messing with the fuel management
Broken Rides:
Old 10-07-2005, 10:38 PM   #13
Suprazeus
Suprazeus is on a distinguished road
Default More hp for the mk3
I would say if you want more hp and torque that isn't too costly change your underdrive pulleys up. I got the Unorthodox racing pulleys (they make them for turbo and NA) and i can definitely feel a difference. But if you can, go with supraman and get the turbo.
Suprazeus is offline   Reply With Quote
Old 10-08-2005, 01:06 AM   #14
Dejvid1785
Dejvid1785 is on a distinguished road
Someone earlier said that underdrive pulleys are bad for mkIII's. For Supraman's info, i have a 7m-gte sittin in the garage ready to rebuild, this is just somethin between time, i figure since i have some money on the side to try and make a pretty damn fast non turbo, i think it would be an awesome accomplishment to step up next to a turbo supra and leave it in a non turbo supra.
88 Targa: Exhaust, Headers, Intake
Dejvid1785 is offline   Reply With Quote
Old 10-08-2005, 01:14 AM   #15
Suprazeus
Hey go for it man do the turbo! its a great upgrade. I want to i jus don't have the money right now. How are the pulleys bad for the mkiii plez let me know i have had them on there for about 6 months.
Old 10-08-2005, 06:54 AM   #16
SupraMan1784
ahh about the pulleys...all i remember is sometin about drag racing...and its better that you change them if thats how you want the car setup, turbo is always nice...though i will definitely admire you if you can hook up a nonturbo to be as fast as a turbo...without the heavy cams
Broken Rides:
Old 10-09-2005, 04:11 PM   #17
Dejvid1785
I think the NA project is a possibility, i will let yall know how it goes, if anybody remembers the down side of the pulleys, let us know.
Old 10-10-2005, 12:48 AM   #18
rnoswal
rnoswal's Avatar
Well someone commented that the crank pulley wasn't a dampener pulley. I can's understand why someone would offer one that wasn't but you need that part on the crank.
The best you can do is get the air in and out as fast as you can. Compression is the best way to get power. The turbos just stuff more air in and acts the same way as more compression. If you could bump the compression up to 11 to one, I think you can still run on pump gas. Definately get the head ported. The most restrictive part to this whole thing is the intake though. If you could get an intake that could get more air in......well good luck on that. Like I said before, you could do away with the efi system and go for a triple Webber set up that would really wake that engine up.
Anyone know what cfm the N/A intake has at the butterfly? There are things you can do, but it would take an engineer to make all the mechanical and electrical things work well together. Just a chip is not worth the money for the small hp gain.
Keep us up to date on how you are doing.
Russ
Old 10-10-2005, 02:30 AM   #19
Dejvid1785
So do not get pulleys or a chip?
Old 10-10-2005, 11:03 AM   #20
Correct. The pulleys are for the drag strip & those street racers wealthy enough to be tearing down the motor every month or 2, and keeping their car 'race ready' all the time. You know...'Fast & Furious'
1986 Supra performance chip Robert Peck MKIII Supra 3 01-19-2007 03:35 PM
Cant find chip for 1987 supra turbo adellicson MKIII Supra 0 05-08-2006 03:27 AM
