Old 03-05-2012, 04:57 AM   #21
I hadn't heard much about the company at all and I have had no experience with their ICs. The MKIII kit wasn't a perfect fit and even on a stock setup I think it'd be foolish to expect any low cost 'kit' like that to fit perfectly and without some modification. That said I was impressed that it came with real 4-ply, silicone couplers and T-bolt clamps.
Old 03-06-2012, 01:50 AM   #22
Awyman18
yea i mean no matter wat theres some sort of modification that will be done. i ordered my fmic today tho, now just have to order the piping. 2.5" piping to be exact
Old 03-10-2012, 01:41 PM   #23
El Supracabras
El Supracabras's Avatar
I would recommend buying a pre bent kit over trying to figure it out yourself. It saves time and you don't end up with a million couplers under the hood plus the kits have bead rolled ends (something you will appreciate when you start to raise the boost!).
I have had the CX Racing intercooler kit on my car for around 2 years with no problems. The cost was great ($300 shipped) but it is certainly not a "bolt on" kit. Oil cooler AND lines, steering cooler, horns and coolant reservoir needed to be relocated slightly. I also had to enlarge the hole where the i/c piping enters the engine bay on the passenger side. The quality of the i/c was what you would expect for the price. It is huge and looks great behind the grill but is heavier than stock. The piping and couplers were decent but the t-clamps aren't the strongest. If your car is lowered, the i/c piping that passes under the front of the core support can easily be damaged by bottoming out or careless towing (heck even if its not lowered).
Good luck with the install.
Old 03-10-2012, 10:59 PM   #24
Awyman18
yea im contemplating that...and that stupid hole in the passenger fender is so small.....
turbo questions.. corytebeau MKIII Supra 7 11-24-2011 12:20 AM
Purchasing and upgrade questions for a 1993-1996 supra non turbo slayer8925 MKIV Supra 9 04-29-2009 09:31 PM
new here, few questions SoooopRa! MKIII Supra 6 08-29-2006 11:25 AM
