Old 10-04-2005, 06:32 PM   #1
NoRush
NoRush is on a distinguished road
Default 7mgte 2 blown cylinders
I have 89 supra turbo, but it has 2 blown cylinders. I was wondering what my best option was.
  • it to bour them out and switch to bigger pistons
  • buy a new block
  • or just fix the 2 cylinders
thx
NoRush is offline   Reply With Quote
Old 10-04-2005, 08:19 PM   #2
SupraMan1784
SP58GT
unless u want to make some large insane amount of power...theres no need to realy switch to bigger pistons....bigger pistons on a stock engine will theoretically slow you down...more mass...more energy to move that mass, so thats kind of useless, though depending on the extent of the damage...if minor you can bore it or have it ported, but if it is major damage i recommend getting a new block...since itll be the safer route....
Now: Saving for an MKIV
Broken Rides:
Old 10-04-2005, 08:54 PM   #3
rnoswal
rnoswal's Avatar
Just curious by what you mean by blown cylinders. If the block can be bored out and make it usuable again then go for it. You will have a little heavier pistons granted, but the new the rings will be working in a perfectly round hole again and the weight difference will be offset byt the power you make. The say you can't beat cubic inches. I can pretty much guarantee you won't be gaining more than a few grams per piston, but that is why they make oversized pistons.
Make sure the cylinder isn't cracked anywhere though, your machine shop can do that for you. If it is, then is the time to look for another block. Since you may be looking at bigger pistons then maybe you might want to go for a more performance oriented piston, forged perhaps. This is a good time to have the block decked and the head checked out and made flat again.
It is never good to just fix a cylinder or two with these engines. If you are talking sleeves then that is an option, but they don't alway work. That is the time to find another block or another type engine for that car.
Let us know about what happened with the "blown " cylinders.
Russ
Old 10-05-2005, 08:04 AM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
^ good answer!!!
Pics of my build.
Do a diagnostic first!
Old 10-05-2005, 04:01 PM   #5
rnoswal
rnoswal's Avatar
Thanks, that really means a lot!
Russ
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
87 Toy Supra N/A, Running on 4 Cylinders wilvelas MKIII Supra 5 04-24-2006 02:40 AM
blown 7mgte Levi1717 MKIII Supra 4 11-29-2005 02:37 PM
