Old 02-08-2012, 12:34 PM   #1
AznSensation
AznSensation is on a distinguished road
Default Tranny swap
I have a 1991 mk3 supra turbo auto. I made the mistake of buying it automatic. Wat would be the range for a price on a tranny swap?
AznSensation is offline   Reply With Quote
Old 02-08-2012, 12:45 PM   #2
i purchased my supra as an auto aswell. its not a big deal.
front drive shaft, w58 or better, clutch, flywheel, master and slave cylinders lines, clutch and brake pedals from a 5 speed. i may be missing somthings but either way a clutch worth buying is gona run you about 200 dollers. and a trans flywheel and all the other could be up to 500 dollers.
its probly worth buying a parts car, one that does not run so its cheap.
Old 02-08-2012, 12:58 PM   #3
AznSensation
I have no clue how to do a tranny swap myself. How much would it cost for labor at a shop?
Old 02-08-2012, 05:18 PM   #4
Ranma
Ranma's Avatar
Talking
Where can you get a clutch for $200? A new one costs a lot more than that and used ones tend to be trash. A drifter can burn one out in no time flat! My guy came to me with a burnt up clutch. Am positive he was drifted and even if not clutches especially 24 year old ones are OLD.
Old 02-08-2012, 08:25 PM   #5
You can get an OEM equivalent for about that much... or if you're just looking for a disc you can get some performance discs if you shop around.
Old 02-09-2012, 05:53 AM   #6
ochowdero
$1000, roughly, ive seen it cheaper but also seen it up to $3000
i did it myself with no knowledge at all.. its a cake walk if you know where these components go, if not talk to mechanics and friends who know
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
Old 02-10-2012, 01:35 PM   #7
pressure plate and housing for non turbo was about 200. i get a better deal now though...
if you shop online you could find one cheaper.
i would never put a used clutch back on a flywheel.
Tranny swap? norcalkev MKIV Supra 3 09-29-2011 12:28 AM
2jzge engine, tranny swap onlyfishn MKIV Supra 5 01-29-2010 04:42 AM
auto to manual tranny swap sd88supra MKIII Supra 10 11-24-2009 06:25 AM
Tranny swap from an 88 to an 87 Cyberguy1992 MKIII Supra 2 05-27-2009 05:44 PM
Tranny Swap RedMan Non-Generation Specific Questions 0 05-24-2006 09:42 AM
