Old 04-21-2012, 07:11 AM   #31
icey756
ok me and a friend honed the cylinders and im starting to clean up some of the part. Its been so hard to get stuff done with school going on. im going to post another album in my profile after i get it done. But i did get it painted. dad borrowed me money. What a nice guy. looks good in a dark charcoal grey and black.
Old 04-21-2012, 08:54 AM   #32
Why does your signature indicate that you've over torqued the hell out of the headbolts? I hope you're a) actually using studs or b) that's a typo or c) for some reason you used a higher torque because you used a poorer lubrcant than the moly ARP supplies.
Old 04-23-2012, 04:25 AM   #33
icey756
We already went over this on another thread and its because thats what the instructions said that came with the ARP bolts.
And i was wondering if anyone knows of where i can get gaskets for my tail lights?
Old 04-23-2012, 07:52 AM   #34
No, I don't recall it. I see someone else mentioned the difference in one of your threads in passing... It's unimportant. I checked to see if they've updated their online library (which they FINALLY HAVE!!) and they've made a couple changes to the product line.
The rated spec for their head bolts is now 90ft/lbs for head bolts which is the same as the studs when installed with a LOW friction coefficient lubricant (molybdenum or better). Also of note is that while both types of fasteners formerly required ISO size tooling (which a lot of people didn't realize anyway) the studs formerly used 9/16" 12 point nuts but now use 14mm (very close in size but different nonetheless) and the bolts are 1/2" (I can't find anything about that changing)... A lot of people had a miserable time in the past trying to use 13mm sockets.... I really think the last set of studs I installed were actually 13mm though, so ARP may have gone fully metric.
If you have an older kit which specifies the lower torque spec I recommend you stick with what the included instructions say. I would not torque OEM bolts to 90ft/lbs, but rather ARP's former recommendation of 75ft/lbs.
As I'm going to copy this to the fastener FAQ thread I'll add that the bore and thread is 12mm x 1.25.
HELP!: 7MGTE engine block info needed barton MKIII Supra 1 05-19-2010 05:54 PM
HELP!: 7MGTE engine block info needed barton MKIII Supra 6 04-14-2010 09:28 PM
Well crap! Advice needed with shot engine finaltable MKIII Supra 10 03-13-2008 07:35 PM
change oil pump without pulling engine Jjona5 MKIII Supra 2 02-11-2007 03:29 AM
Pulling Engine and trans adamh88 MKIII Supra 3 01-15-2007 05:36 PM
