Old 02-02-2012, 01:10 AM   #1
Kayvinh
Kayvinh is on a distinguished road
Default Clutch won't come back up
Title sums it up. I pushed it down and I have to manually lift it back up with hands. I'm thinking its my slave cylinder or is my clutch burnt out? Bought this car a month ago. I believe the clutch is still stock. Its a 1987.
Kayvinh is offline   Reply With Quote
Old 02-02-2012, 01:25 AM   #2
Floorboard wet? Have you raised the pedal and looked at the fluid level in the master cylinder's reservoir?
Old 02-02-2012, 04:30 AM   #3
sounds like a leak in your master, slave, or lines going to either, as cre said find the fluid, find the leak...
when in doubt, check the tsrm.
Old 02-03-2012, 09:30 PM   #4
newtosupra
newtosupra is on a distinguished road
this happened to me like a couple days ago so i looked at the master clutch cylinder resovoir and it was empty because of leak in a the o rings....so a good spot to start by fixing you're promblem is master cutch cylinder plus its ony 19.99
newtosupra is offline   Reply With Quote
Old 02-04-2012, 12:39 PM   #5
Kayvinh
Thanks for everyones help. It was master cylinder, replaced it. Thanks guys!
clutch pedal problem StonecoreTx MKIII Supra 6 01-07-2010 07:19 PM
Clutch wont go into gear... Help?! Conga1991 Non-Generation Specific Questions 4 07-26-2009 09:17 PM
Clutch kit for a 1993 JDM Toyota Supra SpRuCe Non-Generation Specific Questions 0 04-13-2009 10:20 PM
Vibration around 20 - 30 mph... Clutch Changed Supra_Nubus MKIII Supra 1 09-16-2008 11:16 PM
HElp with sports clutch!! whitequasimodo MKIII Supra 3 05-07-2008 11:06 PM
