Old 02-01-2012, 06:08 AM   #1
Preston
Preston is on a distinguished road
Default not starting
i have a 1987 toyota supra 7mgte engine with brand new turbo.
all of the sudden the car wouldnt start
it doesnt click, the battery is charged.... would it be the starter?
is there anything else i should be checking other than the starter?
Preston is offline   Reply With Quote
Old 02-01-2012, 06:24 AM   #2
When the key is turned to the on position do the various warning lights still light up?
Has the car alarm been set off?
Old 02-02-2012, 01:14 AM   #3
Nathanmkiii
Nathanmkiii is on a distinguished road
mine did the same thing and the car alarm went off and now its been sitting for 2 weeks. what can i do? i replaced the ecu and the igniter and i have spark and it cranks what can it be?
Nathanmkiii is offline   Reply With Quote
Old 02-02-2012, 01:29 AM   #4
The factory alarm has a starter disable. You need to re-arm the factory alarm and then disarm the factory alarm. If you have an after-market it may not be properly integrated try this regardless. Lock the car using the key at either the driver's side or the passenger's side door. Wait for the Security LED on the dash to light up and then wait for it to start flashing (about 30-60 seconds). Now unlock the door with the key at either door or the trunk.
There is a switch mounted to the back of each lock cylinder and they wear out. Typically the passenger door lock and the trunk locks are used so infrequently that they work fine if the driver's side lock is no longer disabling the alarm.
Old 02-02-2012, 04:24 AM   #5
Sonyps307
@ Nathanmkiii if urs is getting spark and turning over and not starting sounds like ur not getting fuel.
Unreliable starting. (Problems starting) Hiccups MKIII Supra 9 06-01-2012 05:33 PM
cold starting problems Cjanik MKIII Supra 9 08-02-2008 06:50 PM
starting motor Dom MKIV Supra 3 04-05-2007 01:57 PM
Starting Issue-Is this common? christutecky MKIII Supra 1 04-25-2006 06:13 AM
engine noise car dies after starting tex1116 MKIII Supra 7 11-18-2005 06:47 PM
