Old 01-12-2012, 03:09 AM   #1
pandrade
pandrade is on a distinguished road
Default NA cams on 7mgte
I have heard around that people are always puting 7MGE cams into the 7MGTE and that there are decent powergains and was woundering if this is true and if it is whats the proper way to do it, or if this is just crap
pandrade is offline   Reply With Quote
Old 01-12-2012, 03:31 AM   #2
I can honestly say I have NEVER heard of anyone putting stock GTE cams into a GE. There's no reason, you'd lose what low end torque you have and need for any off the line performance and as the engine cannot move more than a fraction of what the GTE is capable you would sacrifice intake charge velocity for a volume which you can not meet.
Also, the exhaust cams are the same in both engines, only the intake is different.
Old 01-12-2012, 03:49 AM   #3
pandrade
Same as me, what I have heard is putting the NA cams into the turbo models head and seeing good results not vise versa
Old 01-12-2012, 03:55 AM   #4
Sonyps307
He said GE cams in a GTE. I heard it gives a little low end power but chokes out the top ends. Your better off buying adjustable cam gears.
Old 01-12-2012, 08:10 AM   #5
Wow, don't know how I got that backward...
Nonetheless, it's an old wives tale and has been proven as such several times now by people who've actually profiled the cams, run flow tests and dyno'd with them. They're designed to get air into the N/A as fast as possible and not designed for any higher airflow than perhaps 5% over VE which all you'll see above ambient in a N/A. Once you're in boost they're peaking.... then the dyno reads like a flat lining ECG.
Old 01-12-2012, 01:11 PM   #6
pandrade
So what I'm understanding is that for a little low end power you substantially lose in the mid-high end range and should just get adjustable cam gears on the O.E cams
Old 01-12-2012, 08:24 PM   #7
Not quite... You don't really even get a decent low end bump in TQ as a healthy CT-26A will have you well past the zone where any benefit would be derived in only a few seconds. If you're racing one city block at a time (stop light to stop light) you may find it "better", but then a higher compression N/A with a shorter end gear would still beat you... In the quarter mile or any extended driving where you actually get to shift it's all handicap.
Adjustable cam gears are both overrated and underrated.... The same goes for custom cams. If you want any significant shift in power you really want a set of cams ground for your specific build and driving style... As most can't afford that a set of off-the-shelf upgrade cams paired with adjustable cam gear are the way to go. Adjustable cam gears aren't a waste and if you're going to be buying both but can only do one at a time the gears are what I recommend starting with.... but there is only so much room for tweaking with the stockers (may not seem like it, but once you get some serious cams in there you'll see). The thing with custom cams is that the more aggressive they are the bigger the difference many other factors are going to play... being locked into a static timing is a complete waste as .5? may make or cost a decent amount of power.
88 7mgte styock cams wanted mine are bad badassbob Non-Generation Specific Questions 0 07-06-2008 08:46 PM
NA cams in a 7mgTe? the ghoul MKIII Supra 19 10-03-2007 01:58 AM
na cams on a 7mgte noa324 MKIII Supra 0 09-04-2006 12:11 AM
Looking for good adjustable cams SupraSaver87 Non-Generation Specific Questions 3 08-05-2006 08:43 PM
JDM 7MGTE vs. Amercan cams berniek MKIII Supra 0 01-21-2006 08:32 AM
