Old 01-08-2012, 03:46 PM   #1
Sturbo
Sturbo is on a distinguished road
Default Head Gaskets 7mge
Всем привет.
Подскажите пожалуйста какой толщены должна быть прокладка для двигателя 7mge для понижения степени сжатия 8,4,1
Sturbo is offline   Reply With Quote
Old 01-08-2012, 03:48 PM   #2
Sturbo
Default Head Gaskets 7 mge
Hello.
Tell me please what should be thicker gasket for the engine to reduce 7mge compression 8,4,1
Old 01-08-2012, 05:53 PM   #3
Sonyps307
I don't know if u can lower it that much with just a headgasket. But hks makes a 3.0mm headgasket thats the thickest gasket I've seen.
Old 01-08-2012, 06:23 PM   #4
Sturbo
and the degree of under 3.0 mm ?
Old 01-08-2012, 06:47 PM   #5
Sonyps307
I have no idea sorry
Old 01-08-2012, 09:04 PM   #6
http://www.csgnetwork.com/compcalc.html
Old 01-08-2012, 10:46 PM   #7
Sturbo
Do not install nor turbo engine 7mge?
Advice on this got into the habit.
Old 01-09-2012, 04:57 AM   #8
I don't recommend 7M-GE + turbo. I prefer a full engine swap. If you must, then using 7M-GTE pistons is the best. If you can't then a 3mm HG or custom HG. 3mm will give you around 8.6 or 8.7 but having the block and head machined will remove material so your CR will be higher in the end.
Old 01-09-2012, 09:54 AM   #9
Sturbo
A thickness of the stock which a gasket in the engine 7mge and what is the 7mgte? Someone has changed the gasket? Can compete thickness? Please.
Old 01-09-2012, 07:05 PM   #10
The stock HG thickness (once installed) is 1.27mm. GE and GTE are the same HG.
Head gaskets brand? metal? thickness? carl johansson MKIII Supra 7 09-07-2012 05:11 PM
Supra head gaskets? MA61ME MKII Supra 12 01-17-2012 01:48 PM
Need a rebuilt 7mge Head longhrnut Parts Wanted 2 09-26-2011 06:59 PM
7MGE Head Swap 7MGTE87 MKIII Supra 3 03-27-2010 06:39 AM
7MGE - Stuck with changing Head Gasket??? pasupra MKIII Supra 8 07-31-2006 10:41 AM
