#1 |
![]() Toyota Racing Development Join Date: Apr 2007
No, it's not a Toyota thing... It's a 20+ year old car thing.
Yes, the seal is most definitely on it's way out. A blocked PCV system may contribute but the amount of pressure that would be required to blow the seal would present far more severe symptoms elsewhere. The leak increasing in volume when cold is typical.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#2 |
ok just wondering lol i mean yea i plan on changing the pcv valve anyways, and probably this coming up spring ill change the rear main seal, depending on if the leak is still there or watever. thanks boss
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| leaking engine | Ranma | MKIII Supra | 40 | 11-09-2010 03:18 PM |
| 1987 MK III M7 GTE Oil Pump Seal replacement and other questions? | professorbob | MKIII Supra | 0 | 06-09-2010 01:10 AM |
| Replacing rear pinion seal | bmc52387 | MKIII Supra | 1 | 10-18-2008 11:13 AM |
| Rear Main Seal | mkiiisupra | MKIII Supra | 3 | 09-28-2007 02:31 PM |
| rear seal blown | frankie_lala | MKIII Supra | 2 | 09-02-2005 06:12 AM |
