Old 01-03-2012, 04:08 PM   #1
lmmr74
lmmr74 is on a distinguished road
Default Hard to start
So i did had a BHG. It was fixed, the engine head was machined, news bolts, new gasket etc...I told the mechanic to torque the bolts at 75 lb instead of the 58 mentioned by Toyota. After a road test the car woks fine, no overheating, no loss of water. However i still have the heat soak synptoms that i was experiencing before fixing the BHG, everytime i drive the car and shutt it off, after 30 min if i try to start it again, it's hard to get it started. I had this problem before i fix the BHG...Is this heat Soak? Can this be a problem with the fuel injection system/fuel pump?
Any help will be appreciated!
Regards
lmmr74 is offline   Reply With Quote
Hard Start When Cold And Warm jkbwd2 MKIII Supra 0 07-03-2011 07:39 PM
Cold Start System Testing (hard starting) mrnickleye MKIII Supra 12 11-13-2010 08:32 PM
NEED HELP!!! Car is hard to start and will not maintain idle. Slinks2000 MKIII Supra 0 05-06-2010 08:00 AM
MARK3 ,sometimes hard to start, idle rpm not stable. chinesedawn MKIII Supra 15 02-16-2010 02:15 AM
89Supra hard start atsomepoint Non-Generation Specific Questions 6 07-21-2007 08:05 PM
