Old 12-31-2011, 04:52 AM   #1
Killa B
Killa B's Avatar
Killa B is on a distinguished road
Default short throw shifter
does anyone know of an actual short THROW shifter made for the w58 transmission? i read a post about useing one made for the w56 but it wasnt confirmed that it would work (something about the angle of the shifter) does anyone know?
1989 na turbo supra ~ 3ARacing exhaust 2.5" pipe no resinator, sports package
Killa B is offline   Reply With Quote
Old 12-31-2011, 07:20 AM   #2
The short throw shifters for the R154 MKIII fit.
Note that the shifter is specific to both the transmission's extension housing, linkage, the retainer assembly AND the car. A W58 shifter for a different vehicle will not necessarily fit the MKIII Supra as even the interior trim could be different enough to interfere.
http://www.cygnusx1.net/Supra/Librar...spx?F=3312&P=1
Old 01-02-2012, 06:08 PM   #3
Sonyps307
I had a short shift but the way it was made it had alot of play in it. So I went back to the stock and did then mod to it feels way better. Check it out
http://forums.mkiiisupra.net/bbs/showthread.php?t=25670
Old 01-02-2012, 08:12 PM   #4
Ah, the good ol' "SOGI mod"..... I hate that mod. It shortens the height of the shifter but does not significantly shorten the "throw" all while significantly reducing your leverage. On a W58 it's bearable, on the R154 it's just gross. If you've ever used a *well built* short throw shifter I can pretty much assure you would not be recommending that method.... That or you've got arms like Pop-Eye and shift slowly.
Old 01-03-2012, 04:18 AM   #5
Killa B
Killa B's Avatar
wait i got my transmission out of an 85 celica supra so does that mean i need to get a shifter ot of an MKIII before i try and put the transmission in?
and your saying that all the parts in the short throw kit for the R154 will work for the w58? mainly i just need the bushing that goes on the bottom side of the shifter it shifts sloppy, just figured i would put a short throw kit in now while its not in the car lol
Old 01-03-2012, 04:55 AM   #6
It's easiest to install the shifter once the transmission is in.... otherwise you'll beat the crap out of the shifter as you try to drop or raise the transmission and line it up.
I've never looked for verification in any of Toyota's publications but from personal experience the R series seats seem to be 1 or 1.5mm larger in outer diameter. The inner cup is sized just fine though. You can muscle the seat into place or sand the exterior a little bit (it doesn't take much at all) and it'll pop in smoothly with no effort. My preference is the seat and shifter bushing from Marlin Crawler. Depending on the kit you purchase, the riser for the housing may require/include a different seat... So wait until you have it before ordering anything else.
Old 01-04-2012, 04:08 AM   #7
you can find a short throw shifter for the w58 at celicasupra.com
although its not cheap. 300$ i think...
details can be found here:
http://www.celicasupra.com/forums/sh...oducts-Catalog
Price:$315
Part Number:S3-Short-Shifter
We all know the stock shifter gives you that semi-truck kind of feel, so here is your chance to own the best shifter made PERIOD. The S3 Short Shifter is for both W58 and R154 Toyota transmissions and features:
o 36% reduction in shift throw
o Threaded for Toyota shift knob
o Premium materials used and high quality finish
o Fully assembled, bolt in installation
o Manufactured and assembled in the USA
This shifter is designed by a Supra owner using premium materials:
o The shift rod is 304 stainless
o Upper shift housing is 303 stainless
o Lower housing is T6061-T6 Aluminum
o Insulation is a special polyurethane to reduce sound and vibration
o All precision machined parts are US sourced materials. Only two parts are imported.
Before S3
After S3
Old 01-04-2012, 04:37 AM   #8
Heh... You getting kick backs or what... some sales pitch.
My turn:
The S3 really is one of the best short throw shifters available for the MKII/MKIII Supra (Yes, some MKII owners have installed it)... It's the one I would go with if I were in the market (see: if I still had a MKIII and was worried about the shifter height).
Old 01-04-2012, 04:51 AM   #9
i think the factory shifters are great.
love the way the w58 shifts feels like a truck.
Old 01-04-2012, 04:57 AM   #10
if you just want bushings (sorry i just read that part)
get these:
http://www.celicasupra.com/forums/sh...ft-Bushing-Kit
called the shift-Gasm
and.. its true i ordered some a month ago, was professional and fast 35$ to my door
see below for bushing arrangement
be sure to read all of the first post before considering buying.
Short shifter of a Mk3 TrDSpEeD717 MKIII Supra 5 08-11-2010 09:30 PM
slopy shifter and throw bearing laying on pressure plate suprarat Non-Generation Specific Questions 0 10-22-2009 03:47 PM
short throw shifter Jeff_5_7 MKIII Supra 13 07-02-2009 02:23 PM
short throw famous Non-Generation Specific Questions 2 08-25-2006 07:00 PM
Short Shifter?! 88Supraboy MKIII Supra 4 12-01-2005 09:13 PM
