Old 12-28-2011, 04:06 AM   #1
Pacebomber
Pacebomber is on a distinguished road
Default Heat gauge barley moves from cold
So had to pull the Supra out to temporarily drive and am noticing the heat gauge barely moving from the position its starts at when the engine is cold. It blows warm air but not as hot as what I think it could be. Is it the thermostat? Thanks in advance for your help.
Pacebomber is offline   Reply With Quote
Old 12-28-2011, 04:56 AM   #2
The thermostat is a definite possibility, so is the fan clutch. Inspect the fan clutch and put the thermostat in a pot of water on the stove to see when it's opening. My MKIII always wared up pretty quick but at idle it would still take a while (my MR-2 takes forever)... Did you drive around or just leave it idling?
heat temp gauge flipped? Killa B MKIII Supra 7 10-13-2011 05:28 PM
Cold Heater Hose and No Heat batmmannn MKIII Supra 9 06-18-2010 08:25 PM
Heat Consistancy Issues Chambers MKIII Supra 14 04-07-2008 12:52 AM
Heat?? burton51m MKIII Supra 11 02-25-2007 04:28 PM
