Old 01-05-2012, 07:40 PM   #11
Sonyps307
Yea but he said he had his 7mge rebuilt. Why would he ditch his new motor for a unknown motor unless he is trying to get alot of hp and plans on rebuilding the 7mgte to.
Old 01-06-2012, 12:33 AM   #12
I wouldn't bother so long as GTE pistons are installed or the CR has been reduced some other way. I would also get the stock oil location drilled out versus doing a return to the oil pan, especially if you tend to like boosting while in the "twisties".
Old 01-06-2012, 01:29 AM   #13
Sonyps307
Well I have wiseco piston and eagle rods so I'm good.
Old 01-06-2012, 01:52 AM   #14
Yeah? What's the dish volume (are they GE or GTE or other)? What's your static CR? Are you planning on drilling out the bosses for the GTE's knock sensors? Oil cooling? e t c . . .
I'm not really asking... just pointing out things that many don't consider.
Old 01-06-2012, 02:02 AM   #15
Sonyps307
9:1 compression. Already running a oil cooler with thromsate And yes on the knocks.
Old 01-10-2012, 09:23 PM   #16
Sturbo
Sturbo is on a distinguished road
I think that with a degree in such year shall be 8.4 as for 7mgte? or with the pistons survive?
Sturbo is offline   Reply With Quote
Old 01-11-2012, 02:05 AM   #17
The way those pistons are manufactured allows them to better handle unpredictable combustion and higher temperature; They are made with a different process. You could not safely use "cast" pistons at higher compression ratios.
