Old 09-27-2011, 03:58 AM   #1
87hilux7mge
87hilux7mge's Avatar
Default durafix aluminum welding rod
hey, so im looking for a way to make the outlet manifold for the S/C, and i saw on the suby forum that he just brazed his manifold up.
wasnt sure if he used standard aluminum brazing rod or not, so i started searching, and found this stuff.
apparently its pretty strong and i would think the plenty strong enough for the outlet piece, especially since i wont be going over 15lbs of boost ever probably. i saw this product used to repair an air line on a compressor, so im pretty sure itll hold up to pressure.
my question is, does anyone have any personal experience with it? i plan on gettin some anyway just to try it, and ive already got a ton of aluminum brazing rod. just looking for a slighty stronger setup than that, cuz i can break a double sided braze with my hands (albeit, a little extra force)
my only other option is upgrade welders so i can get a spool gun, and thats pretty spendy.
any opinions or comments? theres also a shit ton of vids on youtube for it. pretty amazing stuff!
Old 09-27-2011, 01:19 PM   #2
El Supracabras
El Supracabras's Avatar
I have always wanted to try those too. I specifically wanted to see how well it can weld inter cooler piping. They're pretty cheap. If you get a box, let us know if they're as awesome as the videos make them seem.
Old 09-28-2011, 01:45 AM   #3
87hilux7mge
thats the plan. ive got alot of other random non-car fixes to try it on. but as long as its not too porous then it should do IC piping great. thats what im going to try it with after i do the outlet manifold and other stuff.
ive been researching it and the personal testimonials ive seen appear to be pretty amazing. it doesnt have a very good charpy test rating compared to a weld, but the tensile strength is nuts.
ill post back with some results, im gonna order some here soon or see if my local oxarc carries it.
In need of custom aluminum work bryanf89 MKIII Supra 0 06-07-2010 02:21 AM
Welding the differential??? dannydavi Non-Generation Specific Questions 10 12-08-2009 08:52 AM
big welding job...arghh help turbedsupra Non-Generation Specific Questions 0 07-20-2009 05:18 PM
Welding TRAFIK Off Topic Forum 4 07-26-2006 06:00 PM
