Old 10-04-2005, 12:52 PM   #11
rnoswal
rnoswal's Avatar
Find a donor at the junkyard, that is really the only way to do the job right because of all the little parts you will need. You will have to mess with the wiring as the wires that plug into the auto are not the same as the one that plugs into the manual. You need to jump the wires that will enable the car to start and find the wire to use the reverse lights. Not a big problem as I found out yesterday, but it took some time. Also the brake pedal will have to be swapped because the auto pad is too wide. The clutch pedal assy does have the holes in the firewall, you just have to take out the cutouts.
Russ
What is involved (all parts, labor, price) in auto to manual swap??? the t3d MKIII Supra 1 01-18-2007 03:01 AM
Auto to Manual Conversion justin1642 MKIII Supra 9 09-18-2006 04:22 AM
Difficulty of changing tranny from auto to manual vas85 MKIII Supra 2 06-03-2006 08:30 AM
Auto vs. manual trans. rnoswal MKIII Supra 9 12-14-2005 01:54 PM
