Thread: Auto to manual?
Old 10-04-2005, 12:52 PM   #11
rnoswal
rnoswal's Avatar
Find a donor at the junkyard, that is really the only way to do the job right because of all the little parts you will need. You will have to mess with the wiring as the wires that plug into the auto are not the same as the one that plugs into the manual. You need to jump the wires that will enable the car to start and find the wire to use the reverse lights. Not a big problem as I found out yesterday, but it took some time. Also the brake pedal will have to be swapped because the auto pad is too wide. The clutch pedal assy does have the holes in the firewall, you just have to take out the cutouts.
Russ
