Old 08-19-2011, 11:54 PM   #1
supraturbo_mk3
supraturbo_mk3 is on a distinguished road
Default Just picked up clean turbo supra $650!!!
I found a pretty clean 88 turbo supra for my brother for $650 a hell of deal!!!!
It has a 7MGE block, head and cams, rebuilt polished CT26 turbo, multi layer metal head gasket ARP studs, machined head and block, AFC fuel controller, knock off SSQ BOV
112K on body came from Virginia beach, TEMS work's fine....Actually still has the original supra floor mats
The bad need's transmission replaced and has a dent on the passenger side and is missing a side mold, but for the price and the year I think it's pretty damn clean and a hell of a deal here is the pictures I took of it
IF IT AINT A SUPRA IT AINT SH*T!!
87 Supra N/A JDM 7MGTE, 8psi, 2.5inch Exhaust, 18inch Rim's, 255/45/18 rear, 255/40/18 front, 3inch DP, Ported 3inch elbow, Stage 2 6 puck Clutch
95 Eclipse GST 15psi, 3inch Stainless Steel Exhaust, 3inch DP, MBC, 2.5inch Upper I/C piping, Short Throw Shifter, Stainless Steel turbo inlet, Type S BOV (Sold)
89 Supra Turbo, 12psi, 3inch Exhaust, Ebay intake, 2.5inch Upper I/C piping, ARP Head Studs, Stainless Turbo Manifold Tial BOV (Sold)
(Sold)
supraturbo_mk3 is offline   Reply With Quote
Old 08-27-2011, 01:01 AM   #2
-1 for the PCV delete, -1 for the evap delete, -1 for the EGR delete, -5 for the wiring, -10 for a GE block with what I presume are OEM internals (-40 if it's got OEM GE pistons), and - another 40 if they didn't install at least the factory oil cooler.
Not a terrible deal overall. You could definitely part it out for more than you paid but I wouldn't put much more into it... or you'll be in for more than it's worth real quick... There's a reason they sold it to you so cheap. I would usually rather buy a MA71 in need of a rebuild than someone else's project MA70 with a GTE swap.... They NEVER do it right and ALWAYS seem to cut corners.
Old 08-27-2011, 03:55 PM   #3
supraturbo_mk3
So far from what I can tell he didn't try to cut corners....The Engine runs really good and he had the block machined, blue printed, and balanced.
He had the had ported and polished, ARP studs torqued to 75lbs, multi layer steel head gasket
Those are OEM internals but it's only going to be used as a daily driver
For $650 I couldn't let my brother pass on it....Like you said if need to be one could easily get far more then what was paid for......So for a daily driver I think it should serve my brother well
(Sold)
Old 08-28-2011, 06:14 AM   #4
If the pistons are GE you can count on things going south sooner than later (unless he put in a THICK HG)... N/A pistons like to "self ventilate" under boost... additional heat + much higher compression (especially if a stock thickness HG is used even after the block and head were shaved) + medium quality, basic alloy + no cooling from oil squirters = detonation = holes in pistons.... plenty of people have "done it right" before this guy, trust me.
IF the oil cooling is in place and either a thick HG 2mm+ or GTE pistons were installed I'd probably give it a thumbs up for a reasonable amount of upgrading and such; Still no oil squirters to cool the pistons is a negative but not as big.
Any idea what oil pump is in there?
You'd also do well to swap out the GE intake cam for a GTE cam; The GTE breathes better up top.
It'll last a little while (more if you get a proper oil cooler setup in there and no one gets the silly idea that "it'll be ok to turn up the boost just for the weekend". And thereafter you'll have a decent parts car... So I guess it's win - win; But don't get your hopes up that it's going to last for a long period of time... most N/A-Ts fail miserably and there's a reason why most people who've done them will say that they will never do another if a factory turbo option is available.
That said I'll get down off this soap box now. Good luck with the car... I'm sure he'll enjoy it.
Old 08-28-2011, 12:51 PM   #5
Awyman18
Yea...I mean, great deal. But I always say "u pay for Wat u get for" and yea, cre is also the supra knowledge master so I would probably listen to him lol
Old 08-28-2011, 06:38 PM   #6
87hilux7mge
87hilux7mge's Avatar
for 650 i dont think its a bad deal. parts are worth a bit so thats a plus. and correct my if im wrong, but isnt the idea to create as much power as possible with the least amount of boost?
i agree the pistons will probably go south fairly quickly, but a high compression (ima guess close to my static compression ratio: 9.58:1 or a lil lower somewhere) low boost setup could potentially have more power. the 7m platform has been gone through like this before and yes, the results were....unfortunate. but i believe it could be done right, ppl have been building small block chevys, hondas etc like this for years. but not by someone willing to get rid of it so cheap. in my mind.
1990 Supra Turbo -Any Good!!? ukferrari MKIII Supra 3 12-13-2009 09:13 PM
what do you think of this setup? Jareduhhhh MKIV Supra 4 02-19-2009 10:38 AM
