#1 |
Super Moderator
Can't help you with the dipstick tube, but the oil pressure gauge is on the exhaust side of the engine. If you were looking at the exhaust side of the engine (and the engine were sitting upright lol), the oil pressure switch would be to the top right towards the front. Stock wiring has a rubber boot that goes around the sensor to help keep debris and such off of it
1989 7MGTE R154 Targa Top White Package w/Blue Interior Driftmotion 57trim CT26, Upgraded Intercooler, 2.25" Hard Pipes, 3" Turbo Back Exhaust with Test Pipe, HKS VPC w/GM 3 bar MAP sensor, APEXi S-AFC, Walbro 255lph fuel pump, ProSport EVO Series Boost / Fuel Pressure / AFR gauges, Lotek a Pillar Gauge Pod, HKS Type 0 Turbo Timer, Eibach Lowering Springs, Tokico Illumina II TEMS struts, custom powder coated Motegi Racing TrakLite wheels |
#2 |
If I remember right, the o-ring goes between the lower tube and the block, the upper tube slides into the lower tube and is then held in place by bolting the tab on it to the turbo.
The sender and wire for the oil press gauge are on the hot side of the engine so look for damaged wiring and possibly a cooked sender. |
#3 |
Do you have a picture you could maybe put up? i have no idea what the sender would look like. unless i can look it up in the hanes manual? but i couldnt find it before
1988 7M-GTE Manual Turbo, Godspeed IC, Stock HG Torque to 90FP W/ Arp bolts, Silicon water hose kit, silicon vacuum hoses, Godspeed radiator, 2 12" electric fans. |
#4 |
About the oil psi gauge...mine "works" but the needle jumps from 40 to 120 and then back to zero. So its very sparatic and random
#5 |
That doesnt mean that every ones will do that dude. My stock boost gauge only works after my psi gets to 1 even though the gauge starts at -4
#6 |
My oil gauge goes up to 120 on cold starts but then stays at 35-40 psi running then at idle it's at 6-10 psi but I have a fresh rebuild with new pump also. I just got some parts off a guy that said his oil gauge jiggled sometimes as running then his motor locked up due to oil pump fail.
#7 |
so i got my dipstick tube today and im not entirely sure if its supposed to snap into place or if it just sits there?
| Thread | Thread Starter | Forum | Replies | Last Post |
| Stock Oil Pressure Gauge | 907mge | MKIII Supra | 4 | 05-14-2010 06:13 AM |
| Oil Pressure Gauge | mkiiisupra | MKIII Supra | 0 | 01-14-2008 02:08 AM |
| Oil Pressure Gauge | Drag0na5h | MKIII Supra | 5 | 03-22-2006 07:25 AM |
| oil pressure gauge problem.... | SCRAMJET | MKIII Supra | 0 | 03-21-2006 06:33 AM |
