Old 08-17-2011, 03:10 AM   #1
MJG
MJG's Avatar
Light at the end of a tunnel? You must be dead or an engineer.
Old 08-17-2011, 03:39 AM   #2
k0170n
k0170n is on a distinguished road
That shouldn't be a problem though if I'm taking the whole engine and a few parts into a new car though? Just put in the ignition coils from the GTE into the GE shell with the GTE harness. This will be the first engine swap on a Toyota I will do, I have done many Hondas and a Subaru...
k0170n is offline   Reply With Quote
Old 08-17-2011, 04:48 AM   #3
btwilson86
Super Moderator
btwilson86's Avatar
Swap out the engines. Leave the harness on the engine when you remove it, you can push the ecu plugs into the engine bay fairly easily. Swap out the ECU's. Swap out the gauge clusters (so your tach works and you have a boost gauge). I'm told the dash wiring harnesses are the same from similar year Supras (pre89 and post89; you will want to verify that). Swap the stuff out that's on the fenders (some parts are different).
That should pretty much cover the basics in the swap, although I haven't actually done it myself (helped someone else do it though)
Old 08-17-2011, 06:14 AM   #4
As you're already swapping the interiors (I assume this means the dash) then swap the dash harness with it... No muss, no fuss. You could have the cleanest possible swap out there if you take your time and compare and swap what's different. There's nothing easier than a COMPLETE swap from an already intact and functioning vehicle. Light at the end of the tunnel.
Otherwise I do believe some of the dash harness wiring will need to be modified (just a few wires, but I can't recall what).
7mgte swap vs 1jz swap Supra Saiyan MKIII Supra 15 04-24-2012 02:58 AM
MKIII 1JZGTE Swap How To! Pic Heavy Travis89Turbo MKIII FAQ 12 03-16-2011 05:22 PM
all their is to know for a 7mgte swap mkiii<3 MKIII Supra 0 10-03-2010 10:23 AM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
2JZ Motor Swap MDellboy420 MKIII Supra 3 09-11-2006 06:19 PM
