Old 08-17-2011, 12:20 AM   #1
k0170n
k0170n is on a distinguished road
Default 7M-GE to 7M-GTE swap help
Hi guys!
I have a few questions about the ECU on these engines and if I were to land a 7M-GTE engine into a car that came stock with 7M-GE, if when swapping the ECU's would I have to re-wire all the wiring harness, or if I could just plug and play because of the similar engines. What all would I need to do, and if you had any advice, what would you give me? I want to swap because the GE car is in tons better shape and is more clean.
Thanks much!!
Colton
k0170n is offline   Reply With Quote
Old 08-17-2011, 02:07 AM   #2
MJG
MJG's Avatar
First of all, I have never done a swap. my opinion is you would be far better off purchasing a GTE wire harness rather than a hack job. The wire harness between the two engines differ.
Depending on the engine you purchase, many include the engine wire harness and ECU.
Old 08-17-2011, 02:32 AM   #3
k0170n
The thing is, is that the GTE comes with the harness, I will have two hole cars. I just want the shell and interior from the GE car. I was just told that I could swap engines (or now wondering if it would be easier to just swap the shell and interior ie seats, carpet, door panals, etc) and just swap ecu's. But if I would have to take off the whole wiring harness, and putting on the other one. I was wondering if I could just skip some pain and time and just swapping the ecu by splicing and soldering some wires to the new ecu.
Old 08-17-2011, 02:32 AM   #4
supraturbo_mk3
supraturbo_mk3 is on a distinguished road
I just went through this.....I have a JDM 7MGTE hooked up to a 7MGE ECU and harness. Don't do it!! It run's dangerously lean, It has no fuel cut (Which can save your ass) There is extra sensor's just flopping around (Looks like shit) and seriously it's such a bastard setup that I can't believe it runs good and pulls hard too. But it's not worth it all the extra work and hassle. I'm buying a GTE ECU and wire harness and redoing all of it. The big problems come when trying to upgrade and tune.....I need a professional tune, no shop will touch it. Make sure you use an R154 transmission if your 5spd because the W58 will fail under the extra power.
IF IT AINT A SUPRA IT AINT SH*T!!
87 Supra N/A JDM 7MGTE, 8psi, 2.5inch Exhaust, 18inch Rim's, 255/45/18 rear, 255/40/18 front, 3inch DP, Ported 3inch elbow, Stage 2 6 puck Clutch
95 Eclipse GST 15psi, 3inch Stainless Steel Exhaust, 3inch DP, MBC, 2.5inch Upper I/C piping, Short Throw Shifter, Stainless Steel turbo inlet, Type S BOV (Sold)
89 Supra Turbo, 12psi, 3inch Exhaust, Ebay intake, 2.5inch Upper I/C piping, ARP Head Studs, Stainless Turbo Manifold Tial BOV (Sold)
(Sold)
supraturbo_mk3 is offline   Reply With Quote
Old 08-17-2011, 02:38 AM   #5
k0170n
Alright, so you do suggest running the GTE harness on the GTE engine? (Duh) lol but will I run into any problems like extra wires, or wires I need to solder into the ECU due to the body requiring them? Or will I just be able to disconnect all of the GE's harness, swap the engine and ECU, then just reconnect all of the GTE harness to the GTE engine?
Old 08-17-2011, 02:40 AM   #6
k0170n
Just coming from a Subaru guy who found out that swapping EJ engines is a pain in the ass, because you have to splice and solder a shit load of wires to a new ECU... I was just hoping that Toyota had the light at the end of the tunnel and it was loads easier
Old 08-17-2011, 03:08 AM   #7
907mge
907mge's Avatar
A 7mgte harness should connect right up to a 7mgte. I would think cutting up a harness and redoing it would be far harder than just switching it out. Also a 7mge has a distr. while the 7mgte uses coil packs which alone will make the harness different.
Old 08-17-2011, 03:10 AM   #8
MJG
MJG's Avatar
Light at the end of a tunnel? You must be dead or an engineer.
Old 08-17-2011, 03:39 AM   #9
k0170n
That shouldn't be a problem though if I'm taking the whole engine and a few parts into a new car though? Just put in the ignition coils from the GTE into the GE shell with the GTE harness. This will be the first engine swap on a Toyota I will do, I have done many Hondas and a Subaru...
Old 08-17-2011, 04:48 AM   #10
Swap out the engines. Leave the harness on the engine when you remove it, you can push the ecu plugs into the engine bay fairly easily. Swap out the ECU's. Swap out the gauge clusters (so your tach works and you have a boost gauge). I'm told the dash wiring harnesses are the same from similar year Supras (pre89 and post89; you will want to verify that). Swap the stuff out that's on the fenders (some parts are different).
That should pretty much cover the basics in the swap, although I haven't actually done it myself (helped someone else do it though)
MKIII 1JZGTE Swap How To! Pic Heavy Travis89Turbo MKIII FAQ 12 03-16-2011 05:22 PM
all their is to know for a 7mgte swap mkiii<3 MKIII Supra 0 10-03-2010 10:23 AM
2JZ Motor Swap MDellboy420 MKIII Supra 3 09-11-2006 06:19 PM
