Old 08-15-2011, 12:52 AM   #1
jkbwd2
jkbwd2 is on a distinguished road
Exclamation 7MGE To 2JZGTE Conversion help
hey all i was wondering what would i need to do a 2jz swap to my 88 non turbo supra i know as far as engine,wiring harness,and ecu but i was wondering about the tranny and the mounting for it cause i know you gotta get a special engine mount for the conversion and for the tranny im not sure if i can use the N/A tranny or a turbo 5 speed one cause i dont wanna do any rigging to the driveshaft so if anyone can please help me on this i would appreciate it
jkbwd2 is offline   Reply With Quote
Old 08-15-2011, 01:46 AM   #2
As far as I know there's not a bell housing which would let you use the W58 (You wouldn't want to use the W58 on a 2JZ anyway... too weak). You may use a R154 with a R154 bell housing from a 1JZ MKIII. You're going to need a different drive shaft anyway about it.... the MKIII Turbo drive shaft *might* fit, I can't recall.
Old 08-15-2011, 06:42 AM   #3
btwilson86
Super Moderator
btwilson86's Avatar
I've read that the 2jzge MKIV Supra had a W58 for the N/A 5 Speed (it's a popular swap into some Lexus cars), so the bellhousing does exist. But I agree with CRE, you want a more robust transmission than that
Old 08-16-2011, 05:45 AM   #4
jkbwd2
ya that seems about right well i have a na 88 supra now and i was either thinking of a 2jz swap or a 7MGTE swap but idk if its worth it to do the 7MGTE plus idk what to get for the swap
Old 08-19-2011, 08:36 AM   #5
87supra7mgte
IIRC i think you need to do a single turbo swap as well, i was looking into doin a 2j swap but decided to heavily mod my 7M, saving progress has started , that might be for the 1j swap though, i just remember reading that if you kept the twins you had to beat the firewall in and i didn't feel like doin that, but other than that its pretty much what these guys are tellin ya-mounts, driveshaft, ecu, harness, intercooler, will probably want a better trans depending on what you want to do to the 2j as well
Tags
2jzgte conversion, mk3 supra, transmission, wiring harness
7mge hp increase info 907mge MKIII Supra 14 02-05-2011 03:03 AM
7mgte to 7mge conversion help wayzhack MKIII Supra 7 09-07-2010 08:22 PM
7mge swap for 2jzgte in 87 supra mk3 TMONEY MKIII Supra 0 07-12-2010 07:43 AM
Need some info on 7MGE turbo conversion. Bloody Ben MKIII Supra 2 03-11-2010 12:26 AM
7mge weber conversion? mk3speed MKIII Supra 0 03-19-2005 10:29 PM
