Old 08-13-2011, 03:51 AM   #1
Paul_NJ
Paul_NJ is on a distinguished road
Default BHG Symptoms, troubleshooting ??
'87 Turbo 140K miles. Aw geez what next? . . . driving today and suddenly lost power in 1 and 2 gear, shaking on acceleration. When I stopped I could smell sweet burning smell. Was told there was white smoke coming thru exhaust, 10 minutes after I shut it off. Just replaced the timing belt last year, and I hate to go thru that again. Can someone give me a good troubleshooting procedure to determine if I have a BHG? Good winter project I suppose . . . can't imagine what it would cost to shop out. Any suggestions?
Thanks
Paul_NJ is offline   Reply With Quote
Old 08-13-2011, 06:46 AM   #2
I'm sorely tempted to tell you to not bother spending time on diagnosis... Whatever it is (out of 2 total options) the head is coming out at a minimum. But, I don't like doing a laborious job unless I'm sure I need to. From what you describe a basic compression test and checking the oil and coolant for contamination should tell you all you need to know.
Old 10-10-2011, 03:25 AM   #3
Paul_NJ
I ran a compression test today. Here are my numbers.
1 = 155 psi
2 = 125
3 = 110
4 = 105
5 = 140
6 = 145
Can you give me any further thoughts? Should I do a leakdown test as well . . . I can borrow a tester. Just want to make sure i get all the info I need now.
Thanks
Old 10-11-2011, 02:29 AM   #4
http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=21
tsrm is saying a 14psi difference between cylinders.
and Minimum pressure should be 128psi.
coolant symptoms italian89supra MKIII Supra 1 05-06-2011 08:54 AM
Blown Head Gasket Symptoms! Dejvid1785 MKIII FAQ 76 04-24-2011 07:59 PM
Troubleshooting Durandal MKIV Supra 13 07-18-2010 12:29 AM
86.5 and 87 symptoms sd88supra MKIII Supra 8 12-05-2007 08:56 AM
Clutch Troubleshooting ivire MKIII Supra 9 11-09-2006 01:29 AM
