Old 08-14-2011, 06:09 PM   #11
from what I remember from past posts that there are two types of fans you can install.. thermostat controlled ones and electrical switch types.. I believe the general consensus was the thermostat controlled ones are the way to go.
Am I close on this. It's been awhile.
Old 08-15-2011, 02:07 AM   #12
If his existing fan is working then adding another isn't going to fix anything.
The fan clutch should get harder to spin the warmer it is (with the engine off). If it's as easy to spin when cold as it is when the engine is hot then it's bad. It should never spin completely freely nor refuse to be moved by hand.
http://www.popularmechanics.com/cars...enance/1772922
http://www.ehow.com/how_5086903_test-fan-clutch.html
There's also the infamous newspaper diagnosis technique but I'm not going to advise that myself... You can find it on YouTube. It's safe enough unless you're an idiot or happen to get startled and throw your hand into a moving belt...
Old 08-28-2011, 08:13 PM   #13
lmmr74
lmmr74 is on a distinguished road
One final question, i want to bleed my cooling system (when i turn off the engine i hear a bubling sound coming from the radiator)...how should i do it? Is there any tutorials available??
Thanks in advance for your help!
lmmr74 is offline   Reply With Quote
Old 08-29-2011, 04:00 PM   #14
pandrade
i got a 87 turbo which came whith one electrical fan and the heavy mechanical fan, so i went to the junk yard and found a N/A 89 i belive and took the shroud and the twin electrical fans, i spliced a few wires, swaped the shrouds and now the fans work great. its was cheap easy and thankfully the 89 shroud can retrofit the 87
Old 08-29-2011, 04:02 PM   #15
pandrade
mine does the same thing as well. i put one of thes pressure caps whith the little pressure relive tabs on it when ever i release the pressure my overflow tank starts to gurgle and bubble. Doesent seem to hurt it any just wierd
Old 10-22-2011, 06:12 PM   #16
icey756
Here is how to burp ur cooling system. Its in the FAQ. When i joined the forum i read almost all the FAQ's. It gives you alot of good info believe it or not.
http://www.toyota-supra.info/forums/...r-bubbles.html
This is the way that i know of on how to "bleed" ur system
Old 10-30-2011, 02:10 AM   #17
pandrade
Okay thanks for the info. Ill check out the faq's
electrical problem! I think!!!!!help!! Boostcrazy61 MKII Supra 0 08-21-2009 12:08 AM
Frustrating electrical problem thebobfoster Non-Generation Specific Questions 1 05-30-2009 09:16 PM
Needing some electrical help happysupraowner:) MKIII Supra 3 04-19-2009 01:16 AM
Oil Pressure...Mechanical or Electrical??? Luvs2slide MKIII Supra 5 08-23-2006 12:42 AM
Intermittent Electrical Problems on a ’93 MKIV gjs_cds Shops & Part Reviews 0 05-22-2006 02:39 PM
