Old 08-10-2011, 03:27 AM   #1
dylansword
dylansword is on a distinguished road
Also, when the car is in neutral, it revs up and spools with no problem at all. And as well as when I peel out, and the tires are spinning, it doesnt cut out..
dylansword is offline   Reply With Quote
Old 08-11-2011, 03:26 AM   #2
El Supracabras
El Supracabras's Avatar
If there are no codes present, you might just have a boost leak. They can be tricky to find. It sounds like it's only happening under boost. You can also check the spark plugs if you haven't changed them in awhile.
Old 08-11-2011, 07:24 AM   #3
Do you have a wideband installed? Is the AFR spiking past 20:1 when this happens? Have you done any tuning? If so, what?
Old 08-11-2011, 05:51 PM   #4
dylansword
I don't have a wideband, but I will be getting one. (Recomindations are valued). And as far as tuning I have the maft pro, and everything is set to what the manual says.
Old 08-11-2011, 11:44 PM   #5
The manual doesn't cover how to tune or any significant fuel adjustments... look to see if the mainscale is anything other than 0 and check to see if the fuel "tune" maps are all zeroed out or not. I know you have a MAFT Pro and it's safe to say I know a tiny bit about them.
Old 08-11-2011, 11:59 PM   #6
dylansword
I don't have the manual for the translator, the car came with everything but that when I bought it. I found everytging I know about it online.
So, could you breifly explain the main scale adjustment? I think I know which ones your talking about for the fuel tune ones.
Also, when the car is running, the tps, o2, and spark all show 0 and don't change... should they?
Old 08-12-2011, 12:28 AM   #7
Here's an old website of mine with some documentation I put together on the system as well as other electronics info: http://www.fadingworld.com/CRE/Autom...ra/Electrical/
This will get you started. I've also got two versions of the manual for the MAFT Pro mirrored on there; You may find a newer version on the FullThrottleTech.com forum as well as firmware updates. For running MAF I don't know of any significant updates worth worrying about right away, so probably best not to screw with it right now.
