Old 08-08-2011, 10:11 PM   #1
suprat
suprat is on a distinguished road
Default Turbo whistle what could it be?
Hey guys im new to the forums and i just bought an 88 toyota supra turbo and i have started to here a whistle sound that i didn't hear before. Ive have only had the car for about 1 week. The guy who had this car before looks like he didn't know what he was doing he put silicone on the turbo inlet pipe and it has since come off and there is a big hole there. This is not my first turbo car but i am not sure if it could be that hole that im hearing that noise or could it be the turbo. I really cant step on it cause i need a maf sensor mine is shot. As soon as i connect it the car stalls out. Do you guys think it would be ok to run the car like that until i can get the maf it cost $400 new and i cant find it used. And do you guys think that sound im hearing could be a bad turbo. Need Help.
suprat is offline   Reply With Quote
Old 08-09-2011, 08:17 PM   #2
MJG
MJG's Avatar
The "whistle" sound is normal for a spooling compressor wheel. Thanks to the "big hole" in your intake tube, it is much more apparent.
That hole is allowing any dirt / dedris, in close proximity, to be sucked into your engine as well.
MAF? Perhaps you mean KVAFM?
At any rate, running the car with a hole in the intake and the AFM disconnected is not advised.
Old 08-09-2011, 08:23 PM   #3
suprat
Thanks man i have the car parked right now and im waiting on a part from prolabtuning but i cant seem to get a hold of them and i orderd the part on 08/05/2011 and i havent recieved a tracking number yet i dont know whats going on i was already charged for the turbo inlet but im getting nothing from these guys.
Old 08-09-2011, 11:37 PM   #4
turbonicsperformance
with the afm disconnected it goes into safe mode and you run really rich which in return spools the turbo easier than normal so its a more apparent noise.
Old 08-10-2011, 01:24 AM   #5
that accordion hose (turbo inlet hose) isn't pressurized (advice a good friend of mine gave.) tape that bitch till you get a new one.. 50 or 60 from champion, you can have it in 3 days. as for the AFM you can get a used one from a junk yard. try looking for an LS 400. I just purchased a new to me, AFM for 75 bucks.. and I did tape and silicone my accordion hose when it cracked and broke on me for 3 days while my new one was being shipped.
it works man.
Old 08-10-2011, 01:26 AM   #6
suprat
I know its not good to run the car like that cause with the car runing so rich it can thin out the oil and cause a worse problem. But man i really need to get this car back on the road. The previous owner didn't seem to know what they were doing to much and once i get this fixed i will start to bring it back little by little to what a supra should be. It just sucks to see what people to these classic cars.
Old 08-10-2011, 01:29 AM   #7
suprat
Hey i order a turbo inlet from another site but i may cancel the order cause its been almost a week and i dont even have a tracking number and i have been calling and sending emails and nothing what site is that champion. can you give me a link bro.
Old 08-11-2011, 07:15 AM   #8
Actually it doesn't. With the AFM disconnected the ECU merely reverts to a default base map, but it's not the same as "safe mode" aka "limp mode". The base map is tuned for the assumption of operation at sealevel (100kPa) and an ambient air temp of 70?F. It's the same map you run when the engine is cold minus the subtle tweaks for air flow correction. You should run around the low 14's when up to normal operating temps, IIRC. Given the absence of any real airflow data you may run rich if you're at a higher altitude or the air temp is higher.
"Safe mode" or "Limp mode" isn't set very easily and when it's active it's completely unmistakable... the car will run like CRAP (and barely that well). Unplug a knock sensor and go for a spin... it's awful.
Old 08-11-2011, 12:13 PM   #9
suprat
Well right now i try not to run the car at all cause the times that i do run it the car bucks like a bronco and i cant give it to much gas cause it will bog on me. If i slowly ease in to the gas pedal and don't go over 3000rpms the car will run up to 60 miles an hr or more but as soon as i give it to much gas it bogs down on me. Thats with the afm disconnected now with the afm connected i have to keep my foot on the gas to keep the car runing and when i take off the bucks no matter what. It wants to shut off everytime i have the afm connected but when i disconnect it the car will stay runing but very rich you can see the black smoke but again once i connect the afm the smoke goes away but the car will stall. Oh and since i wanted to make sure it was the afm i connected and tape it while the car was runing and right when the car was about to turn off i tape it and the car came back to life as soon as i stop hitting the afm the car stalls out.
Old 08-12-2011, 03:04 AM   #10
hmm might have to try that, for the sake of science.
boy that would be a great prank to play on a buddy.
turbo whistle. tak2099 MKIII Supra 5 04-11-2008 09:01 PM
MKIV Turbo Whistle normal? leadfootlen MKIV Supra 2 01-22-2007 01:14 AM
