Old 08-08-2011, 10:11 PM   #1
suprat
suprat is on a distinguished road
Default Turbo whistle what could it be?
Hey guys im new to the forums and i just bought an 88 toyota supra turbo and i have started to here a whistle sound that i didn't hear before. Ive have only had the car for about 1 week. The guy who had this car before looks like he didn't know what he was doing he put silicone on the turbo inlet pipe and it has since come off and there is a big hole there. This is not my first turbo car but i am not sure if it could be that hole that im hearing that noise or could it be the turbo. I really cant step on it cause i need a maf sensor mine is shot. As soon as i connect it the car stalls out. Do you guys think it would be ok to run the car like that until i can get the maf it cost $400 new and i cant find it used. And do you guys think that sound im hearing could be a bad turbo. Need Help.
suprat is offline   Reply With Quote
Old 08-09-2011, 08:17 PM   #2
MJG
MJG's Avatar
The "whistle" sound is normal for a spooling compressor wheel. Thanks to the "big hole" in your intake tube, it is much more apparent.
That hole is allowing any dirt / dedris, in close proximity, to be sucked into your engine as well.
MAF? Perhaps you mean KVAFM?
At any rate, running the car with a hole in the intake and the AFM disconnected is not advised.
Old 08-09-2011, 08:23 PM   #3
suprat
Thanks man i have the car parked right now and im waiting on a part from prolabtuning but i cant seem to get a hold of them and i orderd the part on 08/05/2011 and i havent recieved a tracking number yet i dont know whats going on i was already charged for the turbo inlet but im getting nothing from these guys.
Old 08-09-2011, 11:37 PM   #4
turbonicsperformance
turbonicsperformance is on a distinguished road
with the afm disconnected it goes into safe mode and you run really rich which in return spools the turbo easier than normal so its a more apparent noise.
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
Old 08-10-2011, 01:24 AM   #5
Green7mgte
Supra Forum Moderator
that accordion hose (turbo inlet hose) isn't pressurized (advice a good friend of mine gave.) tape that bitch till you get a new one.. 50 or 60 from champion, you can have it in 3 days. as for the AFM you can get a used one from a junk yard. try looking for an LS 400. I just purchased a new to me, AFM for 75 bucks.. and I did tape and silicone my accordion hose when it cracked and broke on me for 3 days while my new one was being shipped.
it works man.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 08-10-2011, 01:26 AM   #6
suprat
I know its not good to run the car like that cause with the car runing so rich it can thin out the oil and cause a worse problem. But man i really need to get this car back on the road. The previous owner didn't seem to know what they were doing to much and once i get this fixed i will start to bring it back little by little to what a supra should be. It just sucks to see what people to these classic cars.
Old 08-10-2011, 01:29 AM   #7
suprat
Hey i order a turbo inlet from another site but i may cancel the order cause its been almost a week and i dont even have a tracking number and i have been calling and sending emails and nothing what site is that champion. can you give me a link bro.
Old 08-10-2011, 01:31 AM   #8
Green7mgte
http://www.championtoyotaparts.com/
They have the best price, I did the checking around when I ordered mine.
Supra FAQ
Supra MKIII FAQ
Old 08-10-2011, 01:33 AM   #9
Green7mgte
Description Qty Price Core Price Total Price Collision Catalog - 1992 - Toyota - Supra
Engine, Air inlet, Air inlet hose, Elbow to meter, Elbow to meter - W/turbo - W/turbo 1 $46.07 $0.00 $46.07 Status: Sent Sub Total $46.07 Tax $0.00 Shipping $10.50 Handling Fee $0.00 Total $56.57
Supra FAQ
Supra MKIII FAQ
Old 08-11-2011, 07:15 AM   #10
Actually it doesn't. With the AFM disconnected the ECU merely reverts to a default base map, but it's not the same as "safe mode" aka "limp mode". The base map is tuned for the assumption of operation at sealevel (100kPa) and an ambient air temp of 70?F. It's the same map you run when the engine is cold minus the subtle tweaks for air flow correction. You should run around the low 14's when up to normal operating temps, IIRC. Given the absence of any real airflow data you may run rich if you're at a higher altitude or the air temp is higher.
"Safe mode" or "Limp mode" isn't set very easily and when it's active it's completely unmistakable... the car will run like CRAP (and barely that well). Unplug a knock sensor and go for a spin... it's awful.
turbo whistle. tak2099 MKIII Supra 5 04-11-2008 09:01 PM
MKIV Turbo Whistle normal? leadfootlen MKIV Supra 2 01-22-2007 01:14 AM
