Old 09-27-2011, 01:28 PM   #21
El Supracabras
El Supracabras's Avatar
Is that the kit from china? The hose quality doesn't look half bad in the pictures.
The inner diameter of the hose should help you find where it goes to. There are coolant hoses on the throttle body as well as the iac valve and turbo, see if any of those are a match.
Old 09-27-2011, 08:51 PM   #22
icey756
Ok. I have to take off the whole intake basically to replace a hose in the back. I know 2 hoses that i wont be using because they were for to stock BOV.
Old 09-27-2011, 09:55 PM   #23
Awyman18
hey just ideas, it never hurts but yea the hoses look decent
Old 09-28-2011, 11:29 PM   #24
icey756
I am going to use a drain plug to plug the hole on the intake. I still can't figure out where two of the hoses go. Here some pics. Maybe someone will know.
ID:	4236   Click image for larger version
ID:	4237   Click image for larger version
Old 09-28-2011, 11:47 PM   #25
Sonyps307
The little one look alike the one that goes to the bottom of the throttle body or the idle control valve.
Old 09-29-2011, 01:24 AM   #26
907mge
907mge's Avatar
http://www.cygnusx1.net/Supra/Librar...spx?F=1603&P=2
Old 09-29-2011, 06:29 AM   #27
icey756
Does this diagram show all the hoses that are used for coolant and such? Cause my kit came with 21 pieces. I hate being so close to done and not knowing where the other two go. lol.
Old 10-17-2011, 01:58 AM   #28
icey756
alas i am finished. Actually i finished last week. I just got my silicon vacuum hoses and will start putting those in tomorrow. After that i will post some pics and tell how it went. And if anyone is interested i can post where i got the vacuum hose from and the silicon hose kit form as well.
Old 10-21-2011, 11:30 PM   #29
icey756
Alright here's some pics of the silicon hose kit that replaced almost all of my coolant hoses. Also i did the red silicon vacuum lines too. I didnt buy a kit for the vacuum lines. I found a guide that gave me how many feet i would need of each inside diameter. All hoses seemed to be good quality to me. If anyone wants any info on them let me kno.
ID:	4320   Click image for larger version
ID:	4321   Click image for larger version
ID:	4322   Click image for larger version
ID:	4323   Click image for larger version
Old 10-22-2011, 02:58 AM   #30
Sonyps307
Wow that's nice I can't wait to get mine kit
MK3 supra Hose Techniques silicon hoses Micahwc Shops & Part Reviews 8 12-09-2012 09:03 PM
Power Steering Pressure Hose Step by Step SilverMK3 MKIII FAQ 1 02-20-2011 09:38 PM
Sm Vac Hose Under Accordian Hose Chromemoly MKIII Supra 3 07-03-2009 01:19 AM
Silicone hose in EGR lines? Paul_NJ MKIII Supra 3 04-14-2009 04:17 PM
