Old 08-03-2011, 07:58 AM   #1
supraman3000
supraman3000's Avatar
supraman3000 is on a distinguished road
Default mk3 alignment Q?
today went to mr.tires to do a alignment on my mk3 wich i just bought 3 months ago! apter waiting 1hr. 1/2 the guy tells me that he got it preety close to spec he did the toe in,out on rear & front, he says he did the camber on the rear,but that he could not get the nuts free on the control arm that the bolts are frozen that for me to go and look for new bolts or used and replace the ones i have. after i do this then my steering will be straight and that he will redue the alignment .
now is this posible???
supraman3000 is offline   Reply With Quote
Old 08-03-2011, 12:40 PM   #2
it is possible to come across a shop with good people in it sure.. saying he will re do the alignment once you get those bolts off sounds pretty humane to me. or are you asking if its possible to get those bolts off? im sure anything is possible with a torch
Old 08-03-2011, 01:10 PM   #3
El Supracabras
El Supracabras's Avatar
This is all too common on any toyota in Chicago. Those suspension bolts like to seize in the bushing and make life miserable. If you aren't familiar with using a torch, take it to a shop and let them deal with it, seized suspension bolts suck. I know one of the MK3 supra vendors carry the bolts, I think Drift Motion or SIP racing, maybe even Horsepowerfreaks.
This is how I do it.
Name:	torching out some bolts.jpg
Old 08-03-2011, 09:36 PM   #4
haha thats one way of getting the job done!
Old 08-04-2011, 06:58 AM   #5
supraman3000
the guy on the alignment place said that he did not use the torch on them because he did not want to mess up my bushings on the control arm.
can that really happen?
and can i just go to some type of shop and let them heat up the bolts and set them free so i can take it back for a wheel alignment again?
Old 08-04-2011, 11:37 AM   #6
its more like a case of the guy on duety didnt have much experiance with a torch and didnt want to take the chance of messing anything up.. and yea bushings are rubber bro.
Old 08-04-2011, 01:01 PM   #7
El Supracabras
It sounds like the guy at the tire shop is being honest with you. Yeah, fire and rubber don't get along. The bushing will likely melt when heated and need to be replaced as well. That is not included in an alignment and that is why the tire shop doesn't want to mess with it.
New polyurethane bushings are available for pretty cheap. I would suggest stock rubber bushings if you use the car for normal daily driving.
Old 08-07-2011, 04:48 AM   #8
supraman3000
i checked out hpfreaks and the bushings for the lower control arms are from energysuspensions polyurethane bushings can they install these on the stock lower control arms or will i have to get a after market control arm? thanks guys!!
Old 08-07-2011, 01:02 PM   #9
El Supracabras
They should fit the stock arms.
Old 08-08-2011, 12:55 AM   #10
907mge
907mge's Avatar
Driftmotion has them for a little less.
http://store.driftmotion.com/static/i-83126g.php
http://store.driftmotion.com/static/i-83127g.php
hood alignment issues Crop MKIII Supra 2 03-22-2011 11:53 PM
Alignment issue 91ma70 MKIII Supra 3 07-24-2010 08:06 PM
checking out an 86 mk3 tomorrow cvbikeguy MKIII Supra 272 03-25-2010 05:01 AM
Timing issue Cyto MKIII Supra 5 01-08-2010 06:32 PM
alignment of EGR valve Serge MKIII Supra 1 05-06-2008 01:43 PM
