#1 |
Yep, do it all day. You need a meter. Have you tried the SAFC2? Select the KVAFM screen and check for any action there. The wires are probably very brittle (thanks turbo!) and they tend to break because the afm is mounted to the chassis and the wiring is mounted to the engine. There is some movement between the two. Visually check the wiring very closely, look at the pins both in the sensor and on the connector. Give each wire a gentle tug at the connector (found most of them this way). If the wiring checks out visually, start doing the meter tests. If you have any problems or questions, well...you know how this works.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| car suddenly wont start - never ran great anyway, esp. cold, now cranks, but won't st | rjSupra | MKIII Supra | 41 | 03-21-2014 05:27 PM |
| Cold Start Rough Idle | 916MKIIIx2 | MKIII Supra | 16 | 06-02-2011 06:08 AM |
| Rough idle and low RPMs at startup when cold... | Fr0sTbY7eX | MKIII Supra | 7 | 01-27-2011 02:15 AM |
| hesitation, high cold idle and poor gas mileage | sd88supra | MKIII Supra | 14 | 02-06-2007 04:17 AM |
| Rough idle / stalls on cold start? | mk3-drft | MKIII Supra | 3 | 04-08-2005 03:34 AM |
