Old 08-01-2011, 11:37 AM   #1
Blindedlegacy
Blindedlegacy is on a distinguished road
Default Engine cooling senor issues
While in motion my temp gauge sits in the middle of hot and cold. But at idle I see the gauge slowing raise to red then instantly drop back to the center. It only happened once because I try not to let that happen again. It only started doing this recently. And the sensor looks jack up. So what you think I should do.
Blindedlegacy is offline   Reply With Quote
Old 08-02-2011, 12:20 PM   #2
El Supracabras
El Supracabras's Avatar
Sounds like you may have air in the cooling system. Take care of the "jacked up" sensor and make sure the system is full and free of air pockets.
Old 08-02-2011, 01:09 PM   #3
Blindedlegacy
You know where I can get the connector or a wiring harness from
Old 08-02-2011, 01:33 PM   #4
El Supracabras
Which sensor is bad? Or which sensor are you looking at?
I just used female connectors for most of them. Many toyotas use the same sensors, take a stroll through the local junkyard and see if any connectors match yours. Otherwise i think drift motion sells some connectors.
Old 08-02-2011, 02:07 PM   #5
Blindedlegacy
Alot of the connector clips are broken so it slides off
Old 08-02-2011, 02:25 PM   #6
El Supracabras
That's very common an any old car. If you cant find what you need in the junkyard or a vendor, go to radioshack and go through the connectors there until you find something that will work. It's only one wire for the temp gauge, you should be able to at least fix that one..
Flowrate of the Stock Water Pump? Bolarbag MKIV Supra 5 06-03-2008 09:26 PM
