Old 07-24-2011, 02:24 PM   #1
1991 supra guy
1991 supra guy is on a distinguished road
Default removing ac belt
I was unable to find any info directing me to the removal of an ac belt on 91 supra 6cyl, non turbo. There is a pulley that appears to be the one I need to loosen for removal and reinstallation, but after turning bolt the only movement is the bolt backs out. I would appreciate any replys. Thanks
1991 supra guy is offline   Reply With Quote
Old 07-24-2011, 03:18 PM   #2
Green7mgte
Supra Forum Moderator
the ac belt is on the drive pully. so you loosen that..
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 07-24-2011, 04:08 PM   #3
btwilson86
Super Moderator
btwilson86's Avatar
Make sure to loosen the bolt on the front of the tensioner pulley, then loosen the bolt that runs down from the top. If that doesn't work, just cut the belt
Old 07-24-2011, 08:56 PM   #4
1991 supra guy
Default ac belt
Thanks loosening the bolt going through the pulley was the trick. It allowed the tensioner to drop releasing tension on the belt. After removing the belt the clutch does not rotate and the pulley will but just a little it seems almost frozen. How likely is it that the compressor is rebuildable? Have any of you had it done? Is it more cost effective to buy a new remanuf one?Thanks again for the tip.
ID:	4087   Click image for larger version
Old 07-24-2011, 09:00 PM   #5
Grandavi
Grandavi's Avatar
That same thing caught me 2 days ago. I may have to buy a new one now.. lol
As for the compressor.. I usually see them from time to time as people do 2jz swaps and remove it.
Old 07-24-2011, 09:45 PM   #6
87hilux7mge
87hilux7mge's Avatar
ive got two extra 7m a/c compressors sitting in my parts. if u need one lemme know
Old 07-25-2011, 03:15 AM   #7
Green7mgte
sorry bro I thought I posted the diagram from the tsrm.. guess it didn't go through. I havent had a belt on my AC for as long as I owned the car.. saves on gass millage =)
Supra FAQ
Supra MKIII FAQ
Timing Belt mkiiisupra MKIII Supra 8 05-07-2011 07:03 PM
Stripped Jumped Timing Belt batmmannn MKIII Supra 17 05-27-2010 12:48 AM
New Timing Belt Direction Paul_NJ MKIII Supra 2 04-11-2009 01:16 AM
Replacing Timing belt Paul_NJ MKIII Supra 5 03-21-2009 05:35 PM
Photos of my timing belt Nato99 MKIII Supra 7 08-27-2007 09:33 PM
