Old 07-27-2011, 11:38 PM   #11
mirage83
That's your heater valve in the picture. I'm not sure about a GE, but in my GTE the top vacuum line goes to a vacuum pipe just behind and to the left of the main valve.
Old 07-28-2011, 01:36 AM   #12
El Supracabras
El Supracabras's Avatar
Is this what you are asking about?
http://www.supras.com/sogidb/techcen...111mk3vsv1.jpg
Old 07-28-2011, 06:20 PM   #13
sturner
sturner is on a distinguished road
Originally Posted by El Supracabras View Post
That is exactly what I'm talking about. Does that just hook up to a VSV or something underneath there? And the other line coming out, where does that go? Thanks!
sturner is offline   Reply With Quote
Old 07-28-2011, 07:37 PM   #14
El Supracabras
As mirage83 posted, that is the heater control valve and the VSV for it. The other vac line goes to the nipple an the back of the intake manifold. At least that is how mine is.
Old 07-28-2011, 08:11 PM   #15
sturner
Could you post a picture of the line on the intake manifold? I dont have any more open valves to connect to. SO the small line runs to the vsv under the heater control and then the other line to the manifold correct? Thanks for all the help. I just installed a "new" 7MGE and finally got it running right now I just wanna make sure everything is connected to its right spot.
Old 07-28-2011, 08:25 PM   #16
El Supracabras
Just use a T and tap off another vacuum hose if you have no more open ports. My car has it going to a nipple on the back of the manifold facing the firewall.
Old 07-28-2011, 09:43 PM   #17
sturner
I knew it, unfortunately that broke off during install. I will just tap into another system as you noted. Thanks for all the help!
Old 12-31-2011, 09:08 PM   #18
sbualuba
sbualuba is on a distinguished road
Originally Posted by 87supra7mgte View Post
Purge line from charcoal canister goes to the BVSV on the thermostat housing, should have 2 fittings on it and from the top of it to the left side of your throttle body when looking at it from the drivers fended. This is to keep your combustion temp down after warm up.
Could i get a pic of this?
sbualuba is offline   Reply With Quote
Old 01-01-2012, 08:05 PM   #19
This thread's rather confusing and unclear, IMO.... What do you need info on? The charcoal canister?
vacuum line diagram/pix? 7mgte 87supra7mgte MKIII Supra 0 06-14-2011 03:56 AM
JDM vacuum lines. please help! Suprasexy MKIII Supra 2 01-04-2011 01:34 PM
really could use help - vacuum, race on the 26th carl johansson MKIII Supra 2 12-24-2007 11:37 PM
Newbee: Question About Vacuum lines.. Alejo_NIN MKIII Supra 3 01-12-2006 07:18 AM
vacuum advance/retard tonster MKII Supra 0 09-16-2005 06:43 PM
