Old 07-17-2011, 05:10 AM   #1
supraman3000
supraman3000's Avatar
supraman3000 is on a distinguished road
Default Question? Would a porsche trans be installed in a 7mg engine?
Just wondering if a porsche transmision would be able to fit on a 7mge/gt engine and would it be better than the r-154 and w58,what would you need to make it work if it does? Just wodering and hope someone has an answer?
supraman3000 is offline   Reply With Quote
Old 07-17-2011, 05:16 AM   #2
what is wrong with those transmissions
Old 07-17-2011, 04:16 PM   #3
perhaps he has one on hand.
Old 07-17-2011, 05:00 PM   #4
i would imagine you would need to have a bell housing made or an adapter plate to go on the trans. to fit a w/58 or r154 housing. and a custom flywheel.
if your engine is Yoda and your car is Yoda, make ity simple and keep your trans YODA
Old 07-17-2011, 09:31 PM   #5
the force is strong with this one.
Old 07-18-2011, 06:44 AM   #6
87hilux7mge
87hilux7mge's Avatar
theres no reason the r154 wouldnt be strong enough. got a buddy running about 500 through his stock one, no problems and he drives it hard (its in his buggy).
but if its something you want to do, and you got some money, mad machinist skills or a good buddy that has said skills, i dont see why not. as long as you can get the proper type of clutch setup with it, you should be able to use the stock type supra flywheel and pressure plate, and a porsche disk.
canadian, how goes the car/engine building?
Old 07-18-2011, 11:59 PM   #7
good, just got to buy a battery and air filter and im ready to try and crank it over.
put mostly everything together on the head with just wrenches, my ratchets were a long ways away and i got a dui so i cant drive and get them...
the wheels on the buss go round and round only 2 months to go
Old 07-21-2011, 08:25 AM   #8
supraman3000
i was just wondering about that. cuz i've seen this sick shop were i rebuild my engine on hunts point,bronx,nyc. he was installing a supra r-154 on a mitsubishi conquest tsi 4 cyl. but he was very secret about his project. when i started asking questions. but all he said was yes we are installing a r-154 on the mitsubishi/dodge. with a great big smile while holding the custom adapter he just brought in the shop! this Puerto rican dude is sick!! really efn good guys he did my hole engine oem stock for $1600 on my 7mgte it was sweeeet!!
88 Supra.. body work and engine question - quickies : ) Grandavi MKIII Supra 5 10-08-2010 04:58 AM
Engine harness question between auto and manual gambit1982 MKIV Supra 4 05-25-2010 05:34 AM
Pulling Engine and trans adamh88 MKIII Supra 3 01-15-2007 05:36 PM
