Old 07-14-2011, 07:53 AM   #1
btwilson86
Super Moderator
btwilson86's Avatar
Stock hp was about 200 for the N/A, 230 for the turbo.
Some things the turbo engine has that the N/A doesn't...
Oil Squirters
Lower compression pistons
Better oil pump (I'm told, haven't confirmed this myself)
Setup for oil feed/return lines to turbo
Setup for 2 knock sensors (N/A has one)
The big one for me is the oil squirters. Everything else is *relatively* easy to make work with a N/A short block.
I also recommend going the GTE swap route versus the N/A-T conversion. You will typically end up with about the same amount of money in it, and the turbo one usually will end up being the stronger platform when it's all said and done.
IMO when doing a swap, you should just buy a parts car with the drivetrain you want. Then you don't have to worry about the sensors and other stuff on the fender you later realize that you need. I just bought me an 87 7MGTE 5 speed parts car for $400 (that's complete engine w/turbo, sensors, R154 tranny, driveshat, rear end, intercooler and piping, wiring harness, ecu, etc). That's not common, but it happens from time to time, so keep searching craigslist!
Old 07-14-2011, 08:34 AM   #2
MK3Newb
MK3Newb is on a distinguished road
Oil Squirters
30hp just for a turbo.... thats Pretty Weak-sauce IMO - I might just save up the money and do a different swap later cause the tranny motor turbos and ecu seems like its gonna cost me around 3k 2jz is 7k roundabout and thats just skimming on ebay for about 20 minuts
MK3Newb is offline   Reply With Quote
Old 07-14-2011, 04:36 PM   #3
Green7mgte
Supra Forum Moderator
lol. then you add a 3'' straight no cat exhaust and a ddp and wow look your not at 300 hp.. all for under 400.. still week sauce?
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 07-14-2011, 05:54 PM   #4
btwilson86
Super Moderator
btwilson86's Avatar
Exactly. You don't swap the drivetrain to keep it stock, that's ridiculous. You swap it for the power potential. The only way to get any real power out of a 7M is to go forced induction, the easiest and cheapest way to get that reliably is to swap in a 7MGTE.
Or you could do a different swap, it's your headache.
Old 07-14-2011, 06:14 PM   #5
MK3Newb
yea im seeing that either way it looks like a long road ahead .. but hey is sounds like a fun one !
The Forum Wars: Season 2 theforumwars MKIV Supra 4 12-16-2010 03:52 AM
Hey New Import Forum.. Check it out import-nut Off Topic Forum 0 01-25-2007 11:13 AM
Supra Forum intertwined with other Imports Adam@D and A Hot Impotrs Off Topic Forum 1 06-20-2005 11:18 AM
Using the Forum suprra_girl Non-Generation Specific Questions 0 04-17-2005 02:12 PM
