Old 07-24-2011, 02:48 PM   #1
1991 supra guy
1991 supra guy is on a distinguished road
Default supra ac
Thanks I unplugged and bypassed one of the switches and the clutch engaged making a terrible grinding noise and smoked a bit, also engine ran very rough. The system did not absorb any of the freon, so I shut it off. My thoughts were if freon was low once absorbing a bit would stop the noise. I did not let this run for long before shutting off. Decided to take it to someone with more knowledge but wanted to get a few thoughts here. The switch i bypassed was reinstalled, now when i start the car I get the same noise from the compressor with ac button off. I'd like to remove the ac belt but the adjustment belt pulley does not move only the bolt backs out, any ideas ? I'm sorry this all seems so scattered. I appreciate all responses.
1991 supra guy is offline   Reply With Quote
Old 07-24-2011, 08:40 PM   #2
speedfiend
speedfiend's Avatar
speedfiend is on a distinguished road
You at least have a bad a/c clutch.
To remove the belt loosen the center pulley nut and then the tensioner bolt.
If all else fails... cut it.
88 N/A targa, 5 speed, tint, thumpin' tunes, APEXi & KYB's, tweaked AFM, Hayden fan...
5 Favorite yodas I've owned, I am a believer!
85 Supra 5 speed, tint, sunroof
77 Celica GT, 20R, 5 speed, tint, cam, header, tweaked Mikuni S/Ds, K&N
91 DX & 99 LE Camrys, for when I did the family thing
86 1 Ton P/U, 22RE, SR-5 speed, tint, buckets, 500w stereo, header, alloys, tweaked AFM, K&N
86 4x4, 22RE 5-speed, tint, 4" lift, cam, header, tweaked AFM, K&N, bored .040
500 character limit...
speedfiend is offline   Reply With Quote
Old 07-25-2011, 08:37 PM   #3
El Supracabras
El Supracabras's Avatar
That terrible grinding noise is never good. It might just be rust grinding off the clutch surface if it hasn't been used in awhile but not likely. Remove the belt and see if it spins by hand smoothly. The car is old, it is probably leaking and should be checked properly for leaks before buying anything. It would be best to replace the compressor and clutch together along with the dryer and some new freon.
Its prolly not gonna be cheap. If you cant handle fixing it all at once just cut the belt off, roll the windows down (and take the top off if your in a targa!) and save your money for gas.
Old 07-25-2011, 09:10 PM   #4
Green7mgte
Supra Forum Moderator
I havent had my ac hooked up in forever. I cant even remember why it's off.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Thermal Fan Clutch - 89 Turbo Supra kstewartnd MKIII Supra 0 10-04-2010 04:36 PM
Clutch kit for a 1993 JDM Toyota Supra SpRuCe Non-Generation Specific Questions 0 04-13-2009 10:20 PM
