#1 |
Just make sure you are using r134 and not r12 since it is ridiculously expensive.
#2 |
Well pulled it apart and the dryer had fallen apart clogging the lines. Cleaned out the lines, recharged and he is frigid as the north pole.
Guess the system prevented the compressor from starting, got off easy on that! I need to replace the fuel tank sensor but on hold. Am changing out a lot of the trim seals during the painting process. Figured this is the best time to do this. Am off to Japan for 6 to 7 weeks. I am going to visit some parts people while there. Hopefully I got most of his mechanical troubles fixed. It is a never ending process. My advice is to check the entire system, again before changing out an expensive component.
