Old 06-08-2011, 09:55 PM   #1
Preston
Preston is on a distinguished road
Default wont go past 2,000 rpms in any gear... HELP!
i have a 1987 toyota supra (turbo)
yesterday i started it up to just drive around town since i havnt driven it in a few days. its running fine and all for probably 3 miles and then started having this problem
in any gear, or nuetral, i couldnt get the engine to rev past 2k rpms
it has done this before but then fixed itself so i didnt worry about it... and now im curious of what is making this problem so i can have it fixed asap.
any suggestions on what i should check out?
ive never herd anything like this so i have absolutely no clue as to what to look for.
Thanks!
Preston is offline   Reply With Quote
Old 06-09-2011, 09:56 AM   #2
87hilux7mge
87hilux7mge's Avatar
id check the TPS and KVAFM and possibly the CPS. those are the only few things i can think of that deal with rpm limitation at the moment..
Old 06-10-2011, 01:52 PM   #3
did you check your codes.
turb boost increase every gear john_lauj MKIII Supra 3 09-29-2010 02:08 AM
wont go past 3000 rpms mk3ben.com MKIII Supra 6 09-22-2007 07:52 PM
1986.5 Idling at high RPMS Sasukevh MKIII Supra 2 06-14-2007 04:56 AM
quick question blacksheep Non-Generation Specific Questions 10 01-01-2007 08:19 PM
used Japanise motor Rpms wont go past 3.5!! Help! Supra89redJapaniserebuiltEng. MKIII Supra 0 12-30-2004 10:04 PM
