Old 06-06-2011, 01:08 AM   #1
STR
STR is on a distinguished road
Default passenger window not working
has anybody had this problem? the driver side one works fine. The passenger one will work sometimes but not all the time. If i put 12v direct to the window motor it will work. Help
STR is offline   Reply With Quote
Old 06-06-2011, 02:43 PM   #2
El Supracabras
El Supracabras's Avatar
Carefully take apart the passenger side switch and check for corrosion between the contacts. If there is any, clean it off with electronics cleaner and sand the contact areas with very fine sand paper (+220). I've seen them so corroded that there were no contacts left after cleaning them, especially on targa models. Same exact symptoms.
Old 06-06-2011, 02:57 PM   #3
STR
but both switches doing the same thing?
Old 06-06-2011, 05:28 PM   #4
Power for the passenger switch is routed through the driver's side. Rework the passenger switch and then if needed do the driver's.... It probably could use it anyway.
passenger side electronics not working ZackNgu Non-Generation Specific Questions 0 04-07-2009 08:42 PM
Passenger Power Window Problems JanusDuo Non-Generation Specific Questions 1 12-17-2008 08:11 PM
passenger window wont open tone loc MKIII Supra 3 06-25-2007 10:37 AM
some f*ck broke my passenger window D_Train MKIII Supra 9 04-29-2007 09:07 PM
Passenger side window kewlcoconut MKIII Supra 1 03-29-2006 07:58 AM
