passenger window not working
has anybody had this problem? the driver side one works fine. The passenger one will work sometimes but not all the time. If i put 12v direct to the window motor it will work. Help
Carefully take apart the passenger side switch and check for corrosion between the contacts. If there is any, clean it off with electronics cleaner and sand the contact areas with very fine sand paper (+220). I've seen them so corroded that there were no contacts left after cleaning them, especially on targa models. Same exact symptoms.
but both switches doing the same thing?
Power for the passenger switch is routed through the driver's side. Rework the passenger switch and then if needed do the driver's.... It probably could use it anyway.
| All times are GMT. The time now is 10:35 PM. |
