Old 06-01-2011, 08:35 PM   #1
Jay633
Jay633 is on a distinguished road
Default 7mgte head gaskets
okay well my machinist said my head cant be shaved no more. so i found a new set of heads but the guy doesnt know how much they shaved off. my concern is what headgasket to drop in there? idk if i pit 1.5,, or 2.0 MHG.also does this head look like it will hold or no?
Jay633 is offline   Reply With Quote
Old 06-01-2011, 09:28 PM   #2
El Supracabras
El Supracabras's Avatar
Looks like a cleaned up 7m head (they only have one head not a set). Is the mating surface straight? Are the cam journals in good shape and straight? Cracks around the valves? Serious pitting? Any bolt holes stripped? These are a few things to check. Most of it should have been taken care of if it is a re manufactured head but don't count on it..
How much material is removed from the head and block, piston type as well as desired static compression will determine the head gasket thickness you will need. Talk to your machinist/mechanic about it. If they don't know what you are talking about or seem confused, exit rapidly.
Old 06-04-2011, 05:30 PM   #3
Have you or your machinist considered measuring it? The specs for the original height have been posted here in the past.... may take a little digging but you should be able to track them down.
Looking at a couple pictures only provides 1/10th the useless results as a real, in-person visual inspection... no better than guessing.
Supra head gaskets? MA61ME MKII Supra 12 01-17-2012 01:48 PM
1992 7mgte overheating and blowing head gasket drewmiller5007 MKIII Supra 5 07-04-2010 09:24 PM
Head Gaskets 916MKIIIx2 Non-Generation Specific Questions 0 11-22-2008 12:04 AM
head gaskets cody_18_06 Non-Generation Specific Questions 2 11-08-2005 02:37 PM
