Old 05-25-2011, 11:58 PM   #1
steve0490
steve0490 is on a distinguished road
yes because i have repaired what the codes were calling for and everytime i fix one thing it tells me another, also when i get one code form one ecu, ill swap the ecus (without fixing code flashed) and now after swappign ecus ill get a different code, now my car did short out the power wire, also the wiring harnes burnt up so im thinking those shorts could spiked the voltage, and now that i have replaced the harness and power wire im sitll having issures
steve0490 is offline   Reply With Quote
Old 05-26-2011, 01:09 AM   #2
El Supracabras
El Supracabras's Avatar
Eww fire, that sucks. At least the car wasn't burned up. What exactly was burned? Does the car run?
Old 05-26-2011, 01:10 PM   #3
steve0490
the engine harness burned from a short so i replaced the whole harness car ran great as soon as i put it in gear it ran like shit again i got a code for tps, changed the tps car still ran like shit then itshowed code 11 then code 10 now the car wont run
Old 05-26-2011, 01:47 PM   #4
El Supracabras
You know that little bunched up set of grounds that goes under the intake manifold right by the brake booster? Check those again. Make sure they're perfect. It would be best to check the continuity of the ecu ground if you can too. If the car wont run, somethings missing. Do the basic checks (spark, fuel,etc). Was the harness an exact replacement?
Old 05-26-2011, 04:15 PM   #5
steve0490
I used a dirrect fit harness gas is good grounds are good i havnt checked spark yet but ive tried twp different coilds and tow different distributors
Old 05-26-2011, 05:16 PM   #6
El Supracabras
You must have a lot of extra parts laying around. Me too.
Test for spark first. Check if injectors have power. Check if they pulse. Check timing again. If the wiring is good, something has to be bad. It could very well be the ecu but the only way to be sure is test everything. If everything checks out, there is no question about the ecu.
Old 05-26-2011, 06:40 PM   #7
steve0490
I really think it is because the car ran mint right after i dropped the harness in its when i ptu it in gear and tried to drive it that it started running like shit again, i heard somewhere that a bad alternator could do that is this true or a myth
oil line troubles 91turbo Non-Generation Specific Questions 2 07-26-2009 09:18 PM
engine troubles yota_head MKIII Supra 4 02-21-2007 05:58 AM
Car troubles =[ Sharaz508 MKIII Supra 9 06-20-2006 03:26 AM
Starter Troubles dcrusupra MKIII Supra 1 01-04-2006 09:15 AM
smog troubles tonster MKII Supra 2 09-24-2005 10:21 PM
