Old 05-21-2011, 11:39 PM   #1
supraturbo_mk3
supraturbo_mk3 is on a distinguished road
Default No power and Starter won't turn
Okay when I jump my car with another battery I let my battery charge but as soon as I unhook the other battery everything goes completely dead does not even try, I was not having any problems with my battery prior to this so I really don't think it's a dead cell.
Another problem when I do jump it the starter won't even attempt to turn, I have had starters go out on me and they give you warnings, it struggles and you pretty much know when it's dieing.....I just find these couple things odd wanted to see if anyone had any similar problems.
I have checked the fuses all were good, I checked for a bad ground....My terminals look fine. I have ran over all the basics most people over look. I'm just kinda puzzled by it because before this it ran strong and I have never had a problem with it.
IF IT AINT A SUPRA IT AINT SH*T!!
87 Supra N/A JDM 7MGTE, 8psi, 2.5inch Exhaust, 18inch Rim's, 255/45/18 rear, 255/40/18 front, 3inch DP, Ported 3inch elbow, Stage 2 6 puck Clutch
95 Eclipse GST 15psi, 3inch Stainless Steel Exhaust, 3inch DP, MBC, 2.5inch Upper I/C piping, Short Throw Shifter, Stainless Steel turbo inlet, Type S BOV (Sold)
89 Supra Turbo, 12psi, 3inch Exhaust, Ebay intake, 2.5inch Upper I/C piping, ARP Head Studs, Stainless Turbo Manifold Tial BOV (Sold)
(Sold)
supraturbo_mk3 is offline   Reply With Quote
Old 05-22-2011, 04:17 AM   #2
El Supracabras
El Supracabras's Avatar
Have you checked the actual battery voltage?
Old 05-22-2011, 05:25 AM   #3
supraturbo_mk3
Not yet I plan to tomorrow to see where it's at....Is there any way to check the starter?
(Sold)
Old 05-22-2011, 09:51 AM   #4
You could pull the starter off and bench test it, but it's not very likely that it's the starter. It seems the problem is probably in one of your battery cables. When you jump start it, what happens if you move the negative jumper cable to a chassis or engine ground (like the alternator bracket)?
Probably a dumb question, but are your terminals tightened down on the battery?
Old 05-22-2011, 03:09 PM   #5
Sonyps307
Yea my cables had a dirty connection lost all power but it world start fine when jumped. So I replace the positive connector and cleaned the battery terminals. Works fine now
Old 05-23-2011, 01:56 AM   #6
supraturbo_mk3
No as I stated in my first post I checked the terminals they were fine......Found out my battery is only putting out 3 volts it's dead.....It's weird because it's only a year old
(Sold)
Car wont turn over after swap! Conga1991 MKIII Supra 59 10-20-2010 12:10 AM
Starter issues! Please help bryanf89 MKIII Supra 4 04-10-2010 05:43 AM
No Power At All: Suggestions... panblackrose MKIII Supra 8 05-17-2008 02:15 AM
Starter problemo XtreeX MKIII Supra 8 03-11-2006 01:57 PM
