Old 05-18-2011, 07:56 AM   #1
RonnyPockets
RonnyPockets is on a distinguished road
Default is 4 grand enough??
i have a na 92 mk3 supra, and i want to do a 1jz swap, do you guys think 4g's would be enough?
RonnyPockets is offline   Reply With Quote
Old 05-18-2011, 08:28 AM   #2
87hilux7mge
87hilux7mge's Avatar
depends on how much the motor costs, and if youre going to put it in yourself or have a shop do it.
motors run between 1k and 2k (just guessing) and you usually plan on at least twice the engine cost to do the swap. if rebuilding then its more.
jz engines have a very good track record, so rebuilding may not be necessary. but check whatever you get over thoroughly. if you are doing the swap yourself, write out a budget and parts list before you do anything else. have a plan, and dont just dive in (ask me why not).
work out all parts you will need and want to have, and have a goal in mind, what you want your car to do in the end. that will make your budget estimates much easier to figure for the whole project.
Old 05-18-2011, 11:21 AM   #3
Travis89Turbo
Travis89Turbo's Avatar
If you do it yourself, including the harness then u can squeeze it in for 4g and some change. Here is my how to. Pretty useful and gives u some good tips.
http://www.toyota-supra.info/forums/...pic-heavy.html
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 05-18-2011, 03:18 PM   #4
Sonyps307
Best way is to get a 1jz front clip they go for 2500-4000 an more. With a 1jz clip u will have everything u need and u will know the miles on it from the gauges pod to
Old 05-19-2011, 03:34 PM   #5
gloreboy89
gloreboy89's Avatar
gloreboy89 is on a distinguished road
Default depends
i paid about $3,500 for all of my swap i had my mechanic do. If i remember right i paid $1700 for the whole 1jzte engine.
too lazy to find a funny quote, buuuutttt off the top of my head. "life always= how well you treat your car, put crap in ur car, then car breaks down, then miss important meeting, or work which just so happen u cant miss another day or ur fired... and end up with a crappy life.
driving an '88 supra
gloreboy89 is offline   Reply With Quote
Old 05-19-2011, 09:10 PM   #6
indi
indi is on a distinguished road
Default supra
it should be good----- but hard to put them on
indi is offline   Reply With Quote
Old 05-20-2011, 05:28 PM   #7
Ranma
Ranma's Avatar
Talking
dude, my Supra is a hole in the ground in which I shovel money. A good way to know what will break next is what has not been replaced. Though he is worth it!
