Old 06-07-2011, 12:22 PM   #11
supraman8188
supraman8188's Avatar
supraman8188 is on a distinguished road
I had code 24 but I swapped the afm from my friends car and made no difference..how would I eliminate the afm?
Supe supe!
1986.5 Supra Manual Red Mica(Maroon) w/wing: Custom sound system, 18" Tork Revos, smoked tail lights, markers, and turn signals.
Mods: Eibach lowering springs, Energy poly front upper and lower control arm bushings, custom cold air intake, solid engine mounts, Magnaflow, short shifter, Optima Red Top, other custom fabrications..and yes a bra.
supraman8188 is offline   Reply With Quote
Old 06-07-2011, 09:00 PM   #12
On a GE? With more money than the car is probably worth.
Get the code 24 taken care of. In case you forgot you do have to pull the EFI fuse to reset the ECU after swapping the AFM and if you disconnect the AFM while the ignition is on it'll set a couple codes including 24. Otherwise you've got a wiring or ECU issue which you need to fix no matter what else you do.
