Old 05-15-2011, 02:46 PM   #11
Spartacus
Spartacus is on a distinguished road
Also, I should mention that the problem is very intermittent. sometimes it will run fine for 20-30 miles without it happening. Other times it will happen all day long. Never happens for the mechanic of course.
Spartacus is offline   Reply With Quote
Old 05-15-2011, 09:04 PM   #12
Post specifics for your car when asking for help with problems: Year (done), engine (even if it's an '86.5 if could still have a swapped in 7M-GTE or other engine), and any engine related mods (fuel controller, turbo upgrades, afpr, BOV and how it's plumbed...
GE fuel pumps are just as reliable as the GTE fuel pumps... except for when they're being forced to work overtime from a N/A-T or similar upgrade.
What's the ignition timing set at and is it set right? Disconnect the O2 sensor next time it occurs and see if that changes anything. Test the ECU temp sensor in the kitchen with a pot of water on the stove and check at several temps.
Good luck with it! ciao
Old 05-18-2011, 05:17 AM   #13
mof920
mof920 is on a distinguished road
Hrmn.. I wouldn't know bud. I'm still learning a lot about my supra. I'm cleaning my header right now then sending it to get resurfaced before I give it one more cleaning. Good luck mate.
mof920 is offline   Reply With Quote
Tags
engine, hesitation, idle, stall, stumble
subtle shuttering when accelerating on a brand new engine suprascoot MKIII Supra 2 07-24-2007 11:27 AM
