Old 05-07-2011, 12:16 AM   #11
87hilux7mge
87hilux7mge's Avatar
sweet deal. do a compression test on it. pretty good deal if all the other stuff was done correctly
Old 05-07-2011, 01:10 AM   #12
johnvin
johnvin is on a distinguished road
ok i plan on doing a commprshion test on it , how do you do that on a car motor? is it the same as a small engine ?
johnvin is offline   Reply With Quote
Old 05-07-2011, 07:22 PM   #13
87hilux7mge
id assume its the same, never dont small motor tests. ull need a compression tester (any chain auto parts store), the screw in kind is more accurate.
take all the plugs out, hook the starter up to a battery, put some oil into each cylinder through the spk plug hole (just a lil), install the compression tester into the first plug hole, crank the motor over 6-10 times, or until the pressure gauge levels off. repeat process for remaining cylinders.
anywhere between 150-180 is good. but you want to see them all within 10psi of each other. any more variance and you want to find out why they are lower. a leak down test is also a good idea.
Bad valve guides or piston rings? free_couch MKIII Supra 1 04-06-2011 03:48 AM
piston rings which ones to get? Clorox9 MKIII Supra 0 06-14-2009 04:35 PM
Piston rings Clorox9 MKIII Supra 2 06-07-2009 08:10 PM
Bhg vs worn rings vs valve guides Kuban MKIII Supra 22 04-23-2007 02:18 AM
1jz & 2jz Piston Rings joolhamdi MKIII Supra 4 04-14-2006 02:44 AM
