Old 05-05-2011, 01:04 AM   #1
jcastro
Default MAF adapter
Do the non turbo and turbo differ I want to buy a air intake filter MAF adapter on ebay but they only have non turbo ones
jcastro is offline   Reply With Quote
Old 05-06-2011, 02:26 AM   #2
907mge
907mge's Avatar
They should be the same since the air boxs are the same for ge and gte.
http://www.cygnusx1.net/Supra/Librar...spx?F=1703&P=1
http://www.cygnusx1.net/Supra/Librar...spx?F=1703&P=2
But don't waste your time by putting a exposed air filter that will suck in hot air.
Old 05-06-2011, 03:49 AM   #3
87hilux7mge
87hilux7mge's Avatar
agreed. get some tubing and put a fender well kit or front bumper setup up on it. its not hard to work up a custom CAI.
with the VAFM you wont see a massive improvement unless you couple it with other mods: exhaust, tuning etc.
but you might see a mileage gain...
Old 05-06-2011, 03:02 PM   #4
Travis89Turbo
Travis89Turbo's Avatar
They are not the same. Bolt holes on turbo KVAFM are farther apart.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 05-07-2011, 12:27 AM   #5
907mge
907mge's Avatar
I don't doubt your knowledge but it does list the same part # for the gasket for each.
Old 05-07-2011, 12:30 AM   #6
87hilux7mge
may be a universal gasket.
Old 05-19-2011, 12:57 AM   #7
jcastro
the adapter dose not fit. How ever if you tilt it side ways and bolt it up it works I am just going to use this for now until i find one that dose fit
Old 05-19-2011, 02:59 AM   #8
Sonyps307
Wink
Can u put a KVAFM on a non turbo
blow off valve adapter projekt6 Non-Generation Specific Questions 1 04-04-2006 11:25 AM
Quick release hub adapter!? 88Supraboy MKIII Supra 4 03-04-2006 04:10 PM
Quick release hub adapter 88Supraboy Non-Generation Specific Questions 0 03-02-2006 01:55 PM
Speedometer help HottScennessey MKIII Supra 1 03-19-2005 06:59 AM
